Need help to make Quad II OPT SPICE Model
Old 23rd November 2017, 09:22 AM   #11
jazbo8 is offline jazbo8
jazbo8's Avatar
You misunderstood my post, I was merely showing that the inductance and the resistance are equal for the two halves of the KNF winding.
Old 23rd November 2017, 09:32 AM   #12
jerrylong is offline jerrylong  China
So if I want use the model, I need to add some code in it? could you help me with it?
Old 23rd November 2017, 09:38 AM   #13
jazbo8's Avatar
No, nothing is missing, you can use it as is.
Old 23rd November 2017, 10:06 AM   #14
Thanks I will try it in LT-SPICE
Old 24th November 2017, 02:53 AM   #15
Since there is no symbol of Quad II OPT in Auymi's web. In order to use his SPICE Model I have made a symbol myself.
and I tried to map the pins of Symbol with SPICE Model
but there is some pins that I can not find in SPICE code, like Pin8 to Pin13
further more there are some numbers(Marked in red) in SPICE code that I have no ideal what are they meaning for?
for example, in the following code
* Primary inductance (p-p 3000ohm 11H)
L11 P1 11 2.75H
L12 12 P2 2.75H
It seems that the number 11 refers to B1 and number 12 refers to B2
but in the next following code
*Primary DC resistance
R11 11 B1 100
R12 B2 12 100
It seems that 11 refers to P1 and 12 refers to P2
It is conflicting with each other
Old 24th November 2017, 06:42 AM   #16
jazbo8's Avatar
You do not need to have pins for the internal connections, such as 31, 21, etc. The symbol’s pin names should correspond to the names used in the model (that’s the easiest way).
Old 24th November 2017, 08:45 AM   #17
You do not need to have pins for the internal connections, such as 31, 21, etc. The symbolís pin names should correspond to the names used in the model (thatís the easiest way).
Could you give more detail for how to use this in ltspice? I tried this model with my symbol in ltspice, but can not solve the error.
Old 24th November 2017, 09:12 AM   #18
jazbo8's Avatar
Rename the attached file to "OPT_PP_KNF.asy" and put it in the sym directory.
Old 24th November 2017, 05:27 PM   #19
Thanks a lot for your symbol
I have made a test schematic to test it, but there is still error
Here is my schematic file
OPT_test.zip
Old 24th November 2017, 05:42 PM   #20
I found the problem after I changed prefix from U to X, it works
Thanks a lot
Need help to make Quad II OPT SPICE ModelHide this!Advertise here!
Spice model for GU50 (LT-Spice) voltagezone Tubes / Valves 44 19th November 2013 09:05 AM
opa627 Spice Model vs Ideal Opamp Model HiFiNutNut Chip Amps 7 16th September 2013 11:40 PM
Quad 405 Spice Model 405man Solid State 4 26th April 2007 07:05 AM
SPICE model Prune Software Tools 6 16th October 2004 04:22 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 12:42 PM
