How worn out should NOS tubes look?
Old 19th November 2017, 12:44 AM   #61
Schmitz77 is offline Schmitz77  Germany
Originally Posted by hooman View Post
[ATTACH]Attachment 646524[/ATTACH]
to day every body knows abut original telefunken valves and zaerix story . you can see my el90s in pics.these tubes are magic.
But do you know even the TFK diamond bottom has been faked by laser? Very hard to see just from pics but clearly identified as fake TFK tubes.
Old 19th November 2017, 05:17 AM   #62
hooman is online now hooman  Iran
hooman's Avatar
Yes, everything happens with technology. But I took an honest picture from 5 valves .nos el90 are not expensive .
The curves of the tubes and the correct bias point are necessary for a good sound, but the lamps differ in sound and this is my personal experience
iranaudiotube.blogfa.com
1979.....i lost everything
Old 19th November 2017, 06:03 PM   #63
The curves of the tubes and the correct bias point are necessary for a good sound, but the lamps differ in sound and this is my personal experience[/QUOTE]
This is because we hear materials used and the manufacturing process in combination with operating points. Not more and not less.
Old 20th November 2017, 01:55 PM   #64
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by TonyTecson View Post
here are a couple of real NOS, the plastic cellophane wrapper still intact,
i guess they don't do this anymore today....
i am keeping this in my collection of genuine NOS tubes....
Yes, Tony, especially there's no need for this PCF86 to be pulled out of it's wrapping and box, as I never have seen any reasonable usage for this strange common cathode triode-pentode conbination.
Btw, I'm not able to decipher the characters written on the bigger box...
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 20th November 2017, 02:28 PM   #65
I'm not able to imagine how one would create this elevated rhomb to the bottom of a valve, i.e. by adding glass, by means of a laser?
Best regards!
Old 20th November 2017, 11:11 PM   #66
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Best regards!
a radford circuit can use that tube...
the bigger box contained 10EW7,....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st November 2017, 02:32 AM   #67
Best regards!
The laser takes material away but a rhomb can be cut into the bottom. And under microscope very small cracks in glass are visible different to original tubes.
Old 22nd November 2017, 03:15 PM   #68
w5jag is offline w5jag  United States
... My test system is comcludent and works well. ...... which gives excellent results, at least to me. ...... So this all works with quite good results but it has taken a while (to be exact, nearly 40 years) to have achieved the knowledge and experience. .....
There is a colloquial (sp?) expression in this country called "I know it when I see it" most famously used in the late Supreme Court Justice Potter Stewart's reference to hard core pornography. No doubt he did know it when he saw it, but it was an impossible standard of reference for people practicing in the field who had to make the determination.
I sort of think this is what Schmitz77 is saying - he knows it when he sees it.
I actually feel the same way - I've seen tens of thousands and I think I have a pretty good instinct for unused versus used on most tubes, but I doubt I could ever articulate a clear cut methodology. I just know it when I see it ....
But I have been wrong in the past, and probably will be again in the future. There are some tubes, some transmitting tubes in particular, or graphite coated glass, or other characteristics, where it is just impossible to say with any degree of accuracy.
I think it's much ado about nothing, anyway. If it doesn't work the way you want in circuit, provenance doesn't fix that.
Win W5JAG
How worn out should NOS tubes look?Hide this!Advertise here!
Playing worn albums....unsafe ? ashok Analogue Source 6 12th March 2016 05:02 PM
Martin Logan Sequel II ESL frequency response and worn-out check AndreaT Planars & Exotics 9 10th August 2012 10:59 PM
Want to buy worn or broken Linn Akito and Ittok tonearms! Big_Bill Swap Meet 7 17th February 2011 02:37 AM
Question About Worn Tubes Monjul Tubes / Valves 4 26th September 2010 03:48 PM
Worn Tube Rectifier Monjul Tubes / Valves 1 13th March 2010 08:07 PM
