Is 6X5GT prone to failure?
Old 9th November 2017, 03:38 PM   #1
sutantoroy is offline sutantoroy  Indonesia
Default Is 6X5GT prone to failure?
Regarding to the issue about 6X5 heater cathode shorts melting the transformer:
1. What causing it? I heard: that its related to the physical structure of the rectifier itself (heater cathode separated to close), not properly designed power supply especially regarding the impedance (or resistance??) of the secondaries power transformer to plate which also related to the value of 1st C input filter (maximum 40uf, typically 4uf), too high DC voltage handled by the rectifier causing leakage heater cathode, as indirect heated rectifier it cant tolerate high reverse voltage, some even say it caused by rectifier plate to plate or plate to cathode shorts.
2. What is the solution if still want to use them? (honestly i recently got the 6X5GT failure experience)
Thank you.
Roy
Old 9th November 2017, 03:49 PM   #2
kevinkr's Avatar
Use a dedicated filament winding and tie the cathode of the 6X5 directly to it, no potential difference, no cathode insulation break down issue. (Make sure the filament winding you use is rated for more than the highest voltage possible at the cathode of the 6X5 under high line, and before the other tubes start to draw appreciable load current)
You can also add a UF4007 or similar high PIV diode in series with each plate as is commonly done with the 5AR4.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th November 2017, 04:15 PM   #3
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Where did you get the 40uF maximum from? The only datasheet I found that listed it said 32uF.
It's an 80mA rectifier. If you need to go bigger and have heater current capacity, the 6AX5 goes to 125 mA.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 9th November 2017, 07:54 PM   #4
Eli Duttman is offline Eli Duttman  United States
Consider either a Loctal socket/7Y4 or "hole shrinker"/9 pin mini socket/6X4. Current delivery ability is = and reliability problem reports absent.
Eli D.
Old 9th November 2017, 08:04 PM   #5
stocktrader200 is offline stocktrader200  Canada
fuse the heater winding
Old 9th November 2017, 08:07 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
I have pieces of test equipment that use the 6X5 and have had zero failures. However, they designed the supply with recommended capacitance and resistance in line. That is the other spec that wasn't mentioned, minimum plate resistance. The power transformer makes some of this up.
If you drew enough current to wipe out the transformer, why didn't the line fuse blow?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 9th November 2017, 09:15 PM   #7
if it is like the SX 780 transformer, most of the power is not delivered on a single winding.
therefore if that winding shorts, it may melt and short with itself or adjacent windings before the line fuse blows
Old 10th November 2017, 01:35 AM   #8
anatech's Avatar
Well, over heating and melting is not an instant thing unless very high energy is involved (lightning for example). Under normal circumstances, the HT winding doesn't draw a lot of current, but in fault mode you might be surprised.
-Chris
Old 10th November 2017, 05:25 AM   #9
Is my draw wiring correct? I use separate transformer for heater, it has dual secondaries, one for the 6SN7GTA preamp, else the rectifier. Each secondaries winding rated for 2 amperes, its large enough right? ( i will use them to supply single stage 6SN7GTA with 300VDC HV). What is the function of UF4007 in series with each plate of 6X5GT?
I do have many 6X5GT now, if its ok to use them, i want to still use them, the current for the HV is enough for single stage preamp of 6SN7GTA right? The 40uf is noted in Tung Sol datasheet, i do find each manufacturers have a little difference in mentioning C input notes, but basicly it have the same information to take precaution of the current surge from the transformer secondaries.
-Chris
-Chris
Just like what happened before on my preamp, i do test my new RCA 6X5GT, for about 8 seconds from i turn it on, i saw a some archs in the filament of the rectifier, so i turn it off. check the pin of the rectifier everthing is still ok, but physically notice the rectifier filament have some shiny parts as like it was scratched. Then i decided to use my daily used rectifier, there is humm coming out, try to replugging the rectifier and 6SN7GTA, there is no change. Then i smell burn out thing, turn off the amplifier and preamp, unplug the main cable, i touch the wood case of the transformer its warmer than usually. Decided to open the preamp, and find out the high voltage secondaries being short, 0 resistance in the winding, and find the out layer of the transformer melted. The main fuse is still ok. But i do find the C input of my preamp is to much bigger than the maximum, 180uf...
Old 10th November 2017, 09:42 AM   #10
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Strange. As the maximum heater to cathode voltage rating is 450 Vdc, there shouldn't be expected any issue, unless this and/or the maximum filter capacitor value ratings are violated. The 6X5 clearly appears to be designed to be operated from the same heater supply as the other tubes in the device. Maybe the specific tube itself was faulty? Tying the cathode to the heater eradicates the possibility of an issue here, of course.
Really, and why? Maybe because a recent make's 5AR4 manufacturing quality hasn't too much in common with that of an original Philips/Mullard tube?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Is 6X5GT prone to failure?Hide this!Advertise here!
2SJ162 and 2SK1058 prone to counterfeit ? Tekko Solid State 55 17th March 2016 06:49 PM
Weak or failure-prone sovtek 5AR4 tubes. Duo Parts 1 7th November 2012 12:09 PM
6X5GT PS Problem sled108 Tubes / Valves 18 27th September 2009 02:09 AM
Need ideas - 6L6GA & 6X5GT Ty_Bower Tubes / Valves 35 10th June 2008 01:55 PM
LM3886 very prone to mains noise Andypairo Chip Amps 26 14th April 2005 02:51 PM
