Stereo 12au7/TDA7294 hybrid amp
The output of the tube from the anode is around zero volts DC and ac is passed via coupling capacitor. The valve runs off +/-35VDC so total volts across valve is 70. Seems to sound fine.
The valve is sort of referenced to -35v but I have decoupled the lower and upper rail using 2k2 and 470uF so there is no noise. With no signal in the output is dead silent.
resistor values
Hello Nigelwright,
After populating the board, I notice that the spacing for most resistors allowed for 1/2 w values.
Are 1/4 w resistors suitable for these locations ??
Please advise
Thank you
kp93300
