866a: question on filament transformer
Maybe this is a stupid question, but wanted to x-check to be on the save side...:
I want to build a HV-PSU for a 814a Push-Pull amp which runs at 700V/80mA per channel. So, looking at the Tube rectifiers, the 866A should be more thancapable for the job and is beautiful as well.
I plan to use a classic FW, so 800V-0-800V transformer into two 866A. Normally I would buy for both diodes a 2,5V/10A transformer with CT for the HV.
My question: I have still some filament transformers from a different project, which deliver 0-2,5V-5V on one winding. Can I reuse them ?
My thought: If the filament of the first 866a is connected to 0-2,5 tap and the second 886a is connected to the 2,5-5V tap and the HV goes from the 2,5V tap to the choke-input filter coming next in the chain...should work as well, NO ?
Very good point indeed...how sensitive is the 866a if not enough current is drawn from the beginning on ? I guess I should build in a dropper resistor, maybe with time relais so that the choke-input always behave as such, than the DC would be 700V...
you can see plasma being shifted to one side filament - thats where lower potential is
also the metal shield is welded to one side of filament (cant be on both...)
out of phase -- filament goes to zero volt when plate voltage is at max (max current); so the plasma is spread across whole filament.
it is about using whole emission capacity.
for example hg thyratron can be shut down by -10v.. regulation occurs from 0..-5v depending on plate voltage
one of reasons why you never see gas tubes with heater voltages - because of the u gradient across filament
one of reasons why you never see gas tubes with HIGH heater voltages - because of the u gradient across filament
Thanks, that made sense!
I wonder if it's worth to attempt phase shifting on the heater transformer for audio amplifier purposes.
