tube preamp w/ XLR?
tube preamp w/ XLR?
Old 31st March 2004, 08:35 PM   #1
tomchaoda is offline tomchaoda  United States
Default tube preamp w/ XLR?
A simple question, why it is hard for me to find a tube preamp that has balanced in/out (XLR) in it, whether it is commercial one or DIY one?
Thomas
Old 31st March 2004, 08:44 PM   #2
grataku is offline grataku  United States
Hello fellow New Jerse-an,
I happen to be interested in a balanced tube preamp as well
have a look at this:
http://hometown.aol.com/kevinc927/my...linestage.html
Old 31st March 2004, 08:48 PM   #3
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
That kit over at K&K was developed by Dave Davenport.
He has his own site nowadays.
http://www.raleighaudio.com
I built the linestage kit before it became a complete kit..
built the psu etc myself.
I don't use it balanced...just single ended...I love that preamp.
http://home.zonnet.nl/horneman/kandk.htm you can see some phodies of my build..(Going to redo the build oneday)
Old 31st March 2004, 08:59 PM   #4
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
tube preamp w/ XLR?
Don't forget this one:
http://home.c2i.net/semfielec/tubepre.htm
I one day hope to build a 1 tube/channel version the author sent me via email.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 31st March 2004, 09:30 PM   #5
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Ha, *****es Brew...
Actually it's nothing more than a long tailed pair differential amp, easy enough to build with a single dual triode.
Frank
Old 31st March 2004, 09:33 PM   #6
leadbelly's Avatar
tube preamp w/ XLR?
Originally posted by fdegrove
Ha, *****es Brew...
Old 31st March 2004, 09:39 PM   #7
fdegrove's Avatar
Yep, that and than it goes on "...in a Bottle"
Look at the circuits' title on the website you linked to.
It just so happens I know it as it's member Jam's favourite...
If only the scan was a little cleaner...
Frank
Old 1st April 2004, 02:17 AM   #8
shif is offline shif  United States
shif's Avatar
Default Tubed fully balanced with more...
Have you considered the Cary Audio SLP-2002 preamp?
Fully balanced, 4 separate line gain stages operating in class A triode.
Analog remote volume, cinema by-pass input, single ended triode headphone output, tape monitor, fully regulated high voltage and filament voltage.
http://www.caryaudio.com/products/audio/slp2002.shtml
Old 3rd January 2013, 09:37 AM   #9
reinhard is offline reinhard
[QUOTE=shif;361944]Have you considered the Cary Audio SLP-2002 preamp?
4 seperate gain stages means 4 seperate gain stages. That is not balanced.
Old 3rd January 2013, 09:46 AM   #10
Demsy is offline Demsy  Indonesia
I still have the good old Sonic Frontiers SFL-2, it has balanced input and output
tube preamp w/ XLR?Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 07:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
