Silver micas as coupling caps? - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 31st March 2004, 06:48 AM   #1
Zombie is offline Zombie  Sweden
Default Silver micas as coupling caps?
Hello!
What about 0,1uF silver micas as coupling caps in tube amps - instead of copper foil, beeswax, teflon and PIO?
Tom
Old 31st March 2004, 08:15 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yikes, those things must be enormous!
That's the only reason, besides cost. Which doesn't seem to deter the idi...erm, fanatics.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 31st March 2004, 08:47 AM   #3
Hello!
I asked about the suitability for audio, especially in valve amps...
They aren't that big, 2" x 1 174" x 1/4", 0,3% tolerance, 350V and price is $16 for 10
cheers,
t
Old 31st March 2004, 09:10 AM   #4
Send a message via Yahoo to redwine1118
I expect the high frequency response will be better or even say "TOO much" with the silver mica capacitor as the coupling path.
Old 31st March 2004, 09:16 AM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default I'll take mine without the snake oil....
Since they come pretty close to being the "ideal capacitor", they should be fine
Old 31st March 2004, 12:24 PM   #6
diyAudio Senior Member
fdegrove's Avatar
Amen to that...
350VDC is likely to be a little low for some applications so be careful where you put them.
I'm curious to know what you think about the sound, never found them in .100F values.
Mostly use them in RIAA correction where they do an excellent job.
Frank
Old 31st March 2004, 03:21 PM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Hi Frank,
Did you read this?
http://www.diyaudio.com/forums/showt...664#post262664
Old 31st March 2004, 05:00 PM   #8
fdegrove's Avatar
Hi Peter,
Thanks.
Interesting thread...
To be perfectly honest, I had no idea whatsoever those small values even existed in Teflon.
Currently I use polysterenes or metalized polypropylenes for the simple reason that I don't easily find the silvered micas in the values and tolerances I need.
Metallic powder,he? Never noticed any of it, I swear.
Then again it's not that obvious when you use only a pair per channel burried in a correction network, I presume.
Next time I'll give the Teflons I fair shot.
P.S. I had no idea one could catch a handful of philosophers just by posting an excerpt of a book...
SLIPPERY SLOPES....
Frank
Old 31st March 2004, 05:40 PM   #9
Hi there,
Honestly speaking, I had got an all FET preamp using silver mica capacitor on the feedback channel. This silver mica capacitor is from RS components and have a tolerance of 0.5%
What I should say the sound will be a little bit metallic on the high frequency range. After that I changed the cap into a pp one. The outcome is more musical and natural.
I recommend the application for silver mica cap should be in precision instrument NOT audio.
Rgds,
Red
Old 31st March 2004, 05:59 PM   #10
dhaen's Avatar
Hi Red,
I think the circuit you describe was probably working well with the mica cap. By changing to a "non-ideal" (pp) cap, you were masking a problem that exists elsewhere.
That's my opinion....
Kanpei
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
Silver Mica de-coupling caps hacknet Chip Amps 58 10th September 2003 02:04 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
