Glassware ACF-2 Aikido hum problem
Old 20th November 2017, 07:03 PM   #71
MrJackson is offline MrJackson  Romania
Finally, success!
Thanks to pl802, a solution has surfaced!!! diyAudio - My DIY projects
Reading the post about hum there, I noticed the description about how mismatched capacitors produce 120hz hum while a center tap that's not exactly centered produces a 60hz hum. I disconnected the center tap from the board and... No more 50hz hum. Remember, I'm from Europe. Now, I have a 100hz hum, but much smaller (consistent with the post, which said that a trafo CT issue produced a much higher hum than the mismatched capacitors)
There's still some hum, but now I know how to fix it... and in the meantime I can live with it, unlike before when it made me feel like putting an axe through it.
Old 20th November 2017, 07:25 PM   #72
pl802 is offline pl802  United Kingdom
Great!!
But it's all thanks to alexcp.
Old 20th November 2017, 07:45 PM   #73
True that! Thank you, everyone. Hopefully this will help the other guys who had trouble with theirs.
Glassware ACF-2 Aikido hum problemHide this!Advertise here!
Newbie GlassWare Aikido All in One Questios George61 Tubes / Valves 20 17th December 2012 09:08 AM
Glassware PS-1 problem bentlyg41 Power Supplies 0 15th August 2012 10:44 AM
Aikido Octal Preamp Glassware TCJ with regulated supplies mattattnet Swap Meet 1 4th October 2011 02:05 AM
GlassWare Audio Aikido Rev C 9-pin board - stuffed & tested with 6GU7s beeah Swap Meet 7 15th September 2009 05:27 PM
Toronto - Krell KSA-100MK2 clone boards and Glassware Aikido PCB twitchie Swap Meet 2 8th June 2007 03:12 PM
