Old 30th March 2004, 02:54 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Troubleshooting a 6n1p linestage.
I had this first tube thing I ever built still on my site.
Someone has built it and measured it.
Apparently it drops of quite fast above 10k?
What could be the cause for this?
Bas
Old 30th March 2004, 02:57 PM   #2
Frank Berry's Avatar
The output impedance is rather high.
Perhaps they are using a long cable with lots of capacitance.
Frank
Old 30th March 2004, 02:59 PM   #3
Mmm yes thought it would be something like that...
Thanks Frank
I have suggested..
1.) Running more current through tube.
2.) Bypassing the cathode resistor...Lowers the impedance
3.) Try to make a cathode follower with the tube.
Old 30th March 2004, 04:38 PM   #4
MaciekP is offline MaciekP  Poland
MaciekP's Avatar
the smaller the load resistors, the wider the frequency response gets, but inversely the higher the distortion. So, we rather choose the loading resistor between the factors of 3 to 7 times of Rp of the tube.
I think, that anode resistor, especialy for parralel tubes, are too high. The lack of cathode bypass cap should make the Rp higher and mu lower and for 1K cathode resistor it should also affect the LF...just wondering...
Maciej
Old 30th March 2004, 09:29 PM   #5
diyAudio Senior Member
fdegrove's Avatar
Default FROM THAT OTHER FRANK....
Maciej's quite right IMO so I redrew it a little even though it's still not the best linestage:
Frank
Old 30th March 2004, 11:31 PM   #6
fdegrove's Avatar
Scrap the cct above, this one should be better:
Frank
6n1 tube = 6n1p Jcartella Tubes / Valves 2 24th September 2007 04:00 AM
replace 6N1P with 7308 dsavitsk Tubes / Valves 2 10th July 2007 02:59 AM
6n1p Screen matthew2456 Tubes / Valves 1 22nd January 2007 05:01 PM
6n1p pre with active load Paracelsus Tubes / Valves 7 24th April 2004 01:03 AM
Is 6N1P = 6N7 = ECC31 ddriveman Tubes / Valves 1 18th March 2004 01:09 PM
Copyright ©1999-2013 diyAudio
