Modern ones have XLR inputs in addition to the RCAs. I do not know what they do internally with the XLR inputs.
Attached stock photo from the McIntosh MC-275 owner's manual showing balanced inputs.
The sensitivity is rated at 1.7V for unbalanced and 3.4V balanced which leaves me suspecting it is actually just an unbalanced input switched between RCA and XLR sockets in which case there really is no point to using it in this application.
I would try them at 1+1:1.6 (parallel the secondary). Top of primary to the output capacitor, bottom of primary to ground. Ground the internal shield through a .01uF cap and add a switch to short that cap out to the preamp chassis ground (ground lift). Top of the parallel secondary to pin 2, bottom to pin 3, pin 1 to the shield. Gain and Zout will both go down a bit. You might need to play with the value of the output capacitor.
Analog Devices SSM 2142 Balanced Line Driver
Analog Devices makes a great chip for balanced line driving. Very easy to use and works great!
http://www.analog.com/media/en/technical-documentation/data-sheets/SSM2142.pdf
The cheapest and easiest way to convert the output to balanced is to copy AN003 figure 2.4 A Simple Alternative.
This was adopted by B.Putzeys in his balanced volume control.
If you need to spend money, then you can adopt figure 2.2 using the output transformer. But note that "BEST" is adopting figure 2.3 to FIX the input stage.
And you don't need the FIX if the Receiver is already balanced and you adopt figure 2.4
This is what I thought too, until I saw the stupidity employed by McIntosh in the new version of this amplifier.The cheapest and easiest way to convert the output to balanced is to copy AN003 figure 2.4 A Simple Alternative.
Not inexpensive,but if you own a C22,this may not be a consideration
Buy a pair of these and build them into a dedicated enclosure with RCA ins and XLR outs. No need to modify the pre,and if you don't like the result,you can easily sell them on later. Follow the included schematic.
http://www.jensen-transformers.com/wp-content/uploads/2014/08/jt-10k61-1m.pdf
- Tubes / Valves
- How to add balance output to C22
