TDA7294 with SRPP front end.
Old 13th September 2017, 05:15 AM   #11
lcsaszar is offline lcsaszar  Hungary
Omitting C8 will drop the gain.
Old 13th September 2017, 02:11 PM   #12
stocktrader200 is offline stocktrader200  Canada
The 12au7 in SRPP mode has a gain slightly less then the mu of the tube.
I think the 12au7 is around 20 - 25
the IC has a gain of 33 as drawn in the schematic
you can input the tube stage via a 22k resistor on the inverting pin of the IC along with the grounded NFB resistor increased to 1.5k . This gives a gain of -1 so that the amp will now be non inverting as well
this would leave the circuit gain entirely to the tube stage
Old 14th September 2017, 01:53 AM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Yes I will omit C8 and reduce 7294 feedback resistor to 4k7.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
TDA7294 with SRPP front end.Hide this!Advertise here!
How to tune front chamber of front loaded horn? 3GGG Multi-Way 1 3rd March 2017 12:10 PM
En Vogue Darling SRPP SE SRPP tube amp will this work? pianolydia Tubes / Valves 4 25th August 2013 01:13 PM
Latest project SRPP valve front end with class D MOSFET output stage. nigelwright7557 Tubes / Valves 1 3rd May 2013 06:15 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 09:29 PM
