Finally had time put this together.......826/100TH >> IT >> 250TL. but it motorboating badly. Can only get rid of the problem by adding 2 more LC to separate drivers and power tubes. Or add a complete set of filter for drivers. Is it possible for both driver tubes and power tubes to use the same HT? or there's something I've done wrong ?
Thanks a lot
Thanks a lot
Try simulating your power supply in PSUD2.
PSUD2
Playing with that, I found that LCLCLC power supplies often have bad resonances. It's often better to use larger cap values and/or something like a LCRCRC topology. Possibly simplifying to just LCRC might actually work better, depending on the iron you're using.
PSUD2
- Tubes / Valves
- Motorboating - please need
