6AS7GA as push pull output?
Old 22nd August 2017, 02:36 AM   #1
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Default 6AS7GA as push pull output?
Hey Anyone,
Has anyone ever heard of an amplifier using 6AS7GA output tubes? I first saw them in Bruce Rozenblit's OTL power amp. They were intended for use as DC amplifiers not as audio tubes. But in looking at their specs they are really interesting. Its a low mu twin triode, mu=2, with and extremely low plate resistance of 280 ohms. I'm assuming that if you parallel a single tube the plate resistance would be 140 ohms and then if used in push pull the plate to plate resistance would drop to 70 ohms?
If the 70ohm plate to plate is correct, (My math is always suspect.) in push The output transformer would need a turns ratio of 2.95 to 1 to drive an 8 ohm load. With such a low turns ratio the drawbacks of an output transformer would be minimized. It might even be possible to use a toroid?
But the real question? Has anyone ever heard this tube? Would its sound be worth building an amp with it?
Artificial intelligence is no match for natural stupidity- Red Green
Old 22nd August 2017, 02:52 AM   #2
PRR is offline PRR  United States
PRR's Avatar
The tube is 250V 100mA. A good-power load would be 2.5K per plate, not the matched load you have figured. You can go a long way either way from 2.5K/plate, but not matched if you want serious output.
You will basically be looking at 6L6/EL34 iron.
> mu=2
Which means HUGE drive voltage. For audio, it tends to need a driver supply B+ higher than the power stage B+, an awkward combination. Clever design and large cathode resistor drop can lead to a fine audio amp. (Note that in DC regulator service we can accept less gain than in audio, because distortion is less of a problem and we can load-off the long tail of the cut-off.)
Old 22nd August 2017, 03:44 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I have a pair of 6AS7 PP mono blocs somewhere.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd August 2017, 03:54 AM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
6S19P push-pull.
Do you see an additional transformer?
It is to add voltage for the driver, QQE03/12 tetrodes.
Testing Wavebourn Constellation - 2 amplifier prototype - YouTube
Wavebourn Canstellation - 2 playing in the darkness - YouTube
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 22nd August 2017, 04:00 AM   #5
nerdorama is offline nerdorama  United States
http://www.triodeguy.com/Triodeguy%2...20PP%20Amp.pdf
Never heard it but it seems like a good design.
Old 22nd August 2017, 04:01 AM   #6
BinaryMike is offline BinaryMike  United States
BinaryMike's Avatar
I breadboarded a hybrid PPP 6AS7 amp using a 1K output transformer. It was a successful design that delivered 25~30W, but I never moved forward to chassis construction after I got it working to my satisfaction. Here's the schematic: http://www.diyaudio.com/forums/attac...breadboard-pdf
Old 22nd August 2017, 04:57 AM   #7
artosalo is offline artosalo  Finland
artosalo's Avatar
This is my version. About a dozen of these have been built by Finnish hobbyists.
This produce some 10...12 W. If you want a fair priced class A triode PP-amplifier, this is one candidate.
http://kuva.termiitti.com/image/43328.GIF
Old 22nd August 2017, 06:21 AM   #8
Shoog is offline Shoog
Shoog's Avatar
Built a few but abandoned the valve in the end because they had self resonance issues which was very noticeable with my 100db/w speakers. Produced a high pitched wine which would come and go at random. Others have reported similar experiences in headphone amps using these valves.
Shoog
Old 22nd August 2017, 06:58 AM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
Yeap !
Yves.
Old 22nd August 2017, 07:27 AM   #10
artosalo's Avatar
Yves, why only 140 V at the anode ? How much is the output power with these values ?
6AS7GA as push pull output?Hide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Push-pull output impedance SpreadSpectrum Tubes / Valves 6 6th March 2008 11:38 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push Pull Output Stage Question 316a Tubes / Valves 4 10th February 2003 01:04 AM
