6AS7GA as push pull output?
Old 22nd August 2017, 07:31 AM   #11
artosalo is offline artosalo  Finland
artosalo's Avatar
Produced a high pitched wine which would come and go at random. Others have reported similar experiences in headphone amps using these valves.
I have not heard about such problem from the guys who built those PP-amps.
But we used Soviet made 6N13S tubes. Also no problem with 6080.
Old 22nd August 2017, 08:33 AM   #12
Shoog is offline Shoog
Shoog's Avatar
Has any of them run them on very sensitive speakers or as headphone amps ?
Unless they have their experience isn't comparable.
I have used just about every type of 6080 variant and they all show similar behaviour.
If you do extensive searching on 6AS7 based headphone amps you will come across people reporting the same thing.
Even though I loved my 6080 PP amps, I still think that there are better candidates for the job. I personally think that the PL84/EL86 is a better bet and not excessively expensive. Dealing with the massive drive requirements of a 6080 amp makes for a more complex build in the end. The MU of 2 will really equate to a gain of 1 or less in a real world circuit.
Shoog
Old 22nd August 2017, 10:52 AM   #13
artosalo's Avatar
I don't know about their speakers. Mine are 91 dB Radiotehnika Giant FS-100.
Giant FS-100N | VEF Radiotehnika RRR
But I have measured the amplifier's S/N, which is > 80 dB (unweigted).
True. The driver stage needs to be carefully designed. The MU in actual circuit is (in my case) 1.44 as can be seen from the schematic.
EL86 as a PP/UL is very good choice, better that typical EL84. With 300 V suppy voltage, more than 20 W is available.
With EL84 and +Ub = 300 V, some 12 W is max.
Old 22nd August 2017, 01:11 PM   #14
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
Hi mr2racer. you probably know this OTL circuit:
6AS7GA OTL
Did you ever think of trying 6AS7 as a driver?
It's harder to make real audio than special effects audio.
Alejandro Gonzalez Inarritu
Old 22nd August 2017, 02:08 PM   #15
rsumperl is offline rsumperl  United States
rsumperl's Avatar
Good morning everyone,
Here's a really old data sheet on the 6AS7 that has audio info on it. Hope this helps.
Ray
File Type: pdf RCA 1947 6AS7G Low Mu Twin Power Triode.pdf (88.3 KB, 180 views)
A great pleasure in life is doing what people say can't be done.
Old 22nd August 2017, 02:48 PM   #16
Bigun is offline Bigun  Canada
Bigun's Avatar
You can also use this tube in a SE configuration: my CELLINI triode amp
I still use it occasionally.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 24th August 2017, 12:05 AM   #17
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Thanks everyone for the help. Especially the data sheet with audio information. I was confusing internal plate resistance and plate to plate load resistance. That data sheet was a bit of a disappointment though as it warns to never use the tubes in parallel. Another disappointment was the expected life of the tube of only 400 hours.
As for the noise/whine Shoog mentioned I've found posts dealing with it. Most are for OTL headphone amps. They seem to find it is a product of individual tubes rather than the design of the tube itself. Also, rolling 6AS7, 6080 and 5998 tubes to find examples that are quiet. So it doesn't seem to be limited to 6AS7. Winged C built 6AS7G which would be relatively late model tubes. And yes they are pretty!
On the up side the tubes are inexpensive when compared with other power triodes like 2A3 and 300B. They are NOT DHT tubes. Built a couple of those amps and don't want to again. Also, both power transformers and output transformers would be fairly straightforward. As for the drive requirements from the interelectrode capacitance's, (I'm on thin ice here.) they don't seem more difficult to drive than 2A3?
The audio datasheet mentions the low mu/voltage swing problem and recommends using an interstage transformer to swing the grids. So I would probably start with a known quantity differential amp like Pete Millet's uniamp. Or possibly design from scratch using EDCOR line matchers as interstages and 6N6P as drivers, I have a few.
I've wanted to build a ten watt pure triode amp for a while. Which would be relatively high power I might add. One without feedback. And the differential push pull layout seems the most attractive option. Plus the amp could be done with only four tubes. I'm going to get a quote on the transformers and see where it takes me?
I really didn't need another project but this one feels good!
Artificial intelligence is no match for natural stupidity- Red Green
Old 24th August 2017, 01:21 AM   #18
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
No big deal to use four tube per channel for parallel push-pull, just use individual cathode resistors and bypass caps.
I would take that with a grain of salt. Expect 5,000+ hours.
I'm not sure how much better/worse this would be than using something like a pair of EL34's. Consider that your push-pull output transformer needs to handle a lot of current but only be sized for modest output.
A 2A3 sits at 50-60V of bias usually depending on the design, while you may have 100V of bias on the 6AS7. The 6AS7 sure will need more drive voltage, and if you use some global feedback around the circuit, then you'll need even more!
I think there may be an assumption in that datasheet that one would want the simplest possible amp, and they may be thinking that you could run something like a 6J5 off the same B+ supply as the output stage, then just step that first stage up a ton to get the required drive voltage for the output stage.
You may be a little disappointed when you put your efforts up against a half way decent 300B amp (which can also easily be made to make 10W).
Old 24th August 2017, 06:06 AM   #19
artosalo's Avatar
The datasheet and recommendation is from 1947 when it was common to use interstage transformers.
As you can see from my schematic, there is 370 V supply voltage available for the driver and required drive signal for the output tubes is 245 Vpp, so no problem at all.
The driver stage has also a huge effect to the overall THD. Now it is biased to perform most of the distortion cancelling. The output stage alone has some 3.5...4 % THD at 10 W. With properly biased 6SN7 driver the overall THD is below 1 %.
With an interstage transformer as a driver you won't get such improvement to THD.
Attached the test results of my amplifier.
Old 24th August 2017, 09:06 AM   #20
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
What is even more dissapointing in the datasheet is the large power loss in the cathode resistors. But this is common to all self-biased power triode applications. Thus, I'd prefer smaller cathode resistors, primarily for balancing purposes, and fixed bias, assisted by a servo circuitry.
Best regards!
6AS7GA as push pull output?Hide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Push-pull output impedance SpreadSpectrum Tubes / Valves 6 6th March 2008 11:38 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push Pull Output Stage Question 316a Tubes / Valves 4 10th February 2003 01:04 AM
