I want to make a output transformer of M10
Old 13th September 2017, 07:22 PM   #171
pieter t is offline pieter t  Netherlands
Originally Posted by jerrylong View Post
I finished the coil, Prim 4512 turns(0.13mm), Sec 1370 turns(0.13mm, 4 groups parallel connection)
Attachment 634958
Attachment 634960
A bad design
You used about halve the available winding space.
The c-core halves are not tightly kept together by the bands, so there can not be a stable fixed airgap.
Check if the c-core halves are correctly paired; it looks odd.
Old 14th September 2017, 01:35 AM   #172
jerrylong is offline jerrylong  China
Winding another coil by hand using the same design for comparison
Old 14th September 2017, 01:36 AM   #173
In order to test the conductance and leakage compared with CNC winding one
Old 22nd September 2017, 05:37 PM   #174
Finished the hand winding one
And add 0.08 air gap
Old 22nd September 2017, 05:41 PM   #175
First test inductance by LCR
Test with 100Hz and 1 volts
It is about 38H, why that low?
Old 22nd September 2017, 05:58 PM   #176
Second test the leakage
It is 73.5mH
Old 22nd September 2017, 06:07 PM   #177
jazbo8 is offline jazbo8
jazbo8's Avatar
Read post #166.
Old 22nd September 2017, 08:53 PM   #178
50AE is offline 50AE  Bulgaria
73.5mH is a huge amount of leakage. Do you trust this LCR meter?
A not entirely, but more realistic method of measuring parasitic parameters is to short the secondary, then add a capacitor with a small (10-20nF) value shunting the primary. Then measure the first resonant frequency across the primary. Then measure it again without the capacitor. The later should be the default first resonance and higher than the one with the shunt capacitor
The added capacitor is practically in parallel with the Cp (shunt capacitance), so the resonant frequency will be lowered. To find Cp:
Cp = Cadd / [(Fres1/Fres2)^2 - 1]
Fres1 is the frequency without Cadd
Fres2 is the frequency with Cadd
Old 23rd September 2017, 02:40 AM   #179
What Cadd is meaning?
Old 23rd September 2017, 06:09 AM   #180
jazbo8's Avatar
Cadd = added capacitor.
I want to make a output transformer of M10Hide this!Advertise here!
how to make audio output transformer circuitravi Tubes / Valves 7 26th July 2011 02:42 PM
is it possible to make a transformer out of choke? 44250 Power Supplies 9 3rd July 2011 02:30 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Copyright ©1999-2017 diyAudio
