Audio Note M10 Clone
Old 8th November 2017, 07:01 AM   #231
jerrylong is offline jerrylong  China
Originally Posted by jazbo8 View Post
Beautiful! So how did the transformers work out?
I used the buying OPT for the test, the turn ratio is 33:1, I will test it in real circuit to see if it has the same problems as simulation. I have not finished DIY OPT yet
Old 8th November 2017, 04:21 PM   #232
Tonight I tested the Voltage of each stage, line stage, #2 and #3 stage of phono are fine. There is problem of #1 of phono. Green one is LEFT and Red one is Right, I think something wrong with LEFT, can anyone help me to find it?
Old 8th November 2017, 04:36 PM   #233
I have switched 6072 of left and right, the problem remains on left, so it is not tubes problem
Old 9th November 2017, 01:03 AM   #234
I pull out the 6072 and test the res of each section
1,I have tested the res from B+ to 6072 socket #1 L and R is the same, about 120K
2,socket #3 to #6 L and R is the same,about 2K
3, socket #8 to GND L and R is the same,about 5K
what I missed to lead the problem of LEFT?
Old 10th November 2017, 02:58 AM   #235
Alllensoncanon is offline Alllensoncanon  United States
Have you try changing the Upper Triode grid leak resistor form 10M to 100K?
Old 10th November 2017, 06:19 AM   #236
I haves the problem
This is the right circuit
After I short C1, the result is same as the problem
I take down this cap from LEFT
And changed a new on
Problem solved
Then I tested the cap, it soft breakdown, so it hard to find out this problem when power off
Old 18th November 2017, 01:53 PM   #237
My friend has made a 6.5K:600 OPT, it is finished today. I put them on, it is quite good, till now the clone job of M10 is finished, it sound very good.
then I will use LT-SPICE to test it and compare with the real circuit. If there is any thing to improve I will go on.
Audio Note M10 CloneHide this!Advertise here!
how to make audio output transformer circuitravi Tubes / Valves 7 26th July 2011 02:42 PM
is it possible to make a transformer out of choke? 44250 Power Supplies 9 3rd July 2011 02:30 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
