Audio Note M10 Clone
Old 8th August 2017, 10:27 PM   #11
jerrylong is offline jerrylong  China
The size of the core is 68mm*38mm*38mm(H*W*D), the window size of the core is 42mm*12mm(H*W)IMG_5614.JPG
Old 8th August 2017, 10:34 PM   #12
So I have found a similar one, the size of this one is 82mm*42mm*30mm(H*W*D), and window size is 56mm*15mm(H*W)IMG_5237.JPGIMG_5238.JPGIMG_5239.JPGIMG_5594.JPG
Old 8th August 2017, 10:44 PM   #13
Compare this one with Tran027
Cross-sectional area of Tran: 13mm*2mm*38mm=9.88cm^2
Cross-sectional area of mine: 13.5mm*2nm*30mm=8.1cm^2
The window of Tran027:42mm*12mm
The window of mine:56mm*15mm
The Cross-sectional area of my core is less than Tran027, but window size is bigger
Old 8th August 2017, 10:55 PM   #14
Originally Posted by JonSnell Electronic View Post
I made one, (a hand winding one) back in 1960. I will post a photo when next back in my workshop. It uses a counter from a pre 1960s gas meter on a short piece of bowden cable to the winder.
If you unwind the transformer, measure the wire gauge and count the turns, that is all you need to know. Laminations are widely available and off you go.
Happy days.
Thank you, it is really helpful if you can post some photo of yours. I haven't winded it yet and will measure the inductance of the core by wire a test coil
Old 8th August 2017, 11:09 PM   #15
Thanks for post this email for me, I have read it before, peter is mainly talking about Tran028(the new version) for M10, but can't find the schematic of new M10
Old 8th August 2017, 11:39 PM   #16
Originally Posted by Koonw View Post
I have bought this OPT and used it to make my M10, but not as good as I am expected
Old 8th August 2017, 11:41 PM   #17
Originally Posted by 45 View Post
33 = n^2, so it's 5.744:1.
I thought 33:1 is turn ratio, but not impedance ratio?
Old 9th August 2017, 07:56 AM   #18
45 is offline 45  Italy
45's Avatar
Does it sound reasonable for 600R load and ONLY 110H? Not to me. It is actually rubbish!
Old 9th August 2017, 08:23 AM   #19
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
So I think 3.3:1 will be alright?
seems more realistic to me....or a 5:1 ratio....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th August 2017, 08:32 AM   #20
jazbo8 is offline jazbo8
jazbo8's Avatar
Peter Qvortrup clearly stated "The 027 was approximately 33:1 with a CT." and the reason why they switched to the 028 - to get higher impedance, but otherwise I would guess the schematic stayed pretty much the same.
Audio Note M10 CloneHide this!Advertise here!
how to make audio output transformer circuitravi Tubes / Valves 7 26th July 2011 03:42 PM
is it possible to make a transformer out of choke? 44250 Power Supplies 9 3rd July 2011 03:30 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
