Cathode Bias confusion
Old 13th August 2017, 01:16 AM   #61
45 is offline 45  Italy
45's Avatar
Originally Posted by Wavebourn View Post
Gentlemen, the only way to cancel the function (2 stage) is to multiply it by an anti-function. Have you seen any anti-tube? I did not. You can substitute one from another in PP, but the result would be, only DC and even order parts would be decreased.
So what I see on the scope is a miracle?
It's just about even fuctions and the phase of the amplified signal (including its harmonics). It is only about 2nd harmonic and it's not complete cancellation (i.e. not reduced to zero).
PRR tried to explain that in simple words, I think.
Old 13th August 2017, 02:04 AM   #62
Shef is offline Shef
Shef's Avatar
Gents, I think, the truth is in between, as always.
The carefully picked tubes and adjusted operating points can mutually exclude some THD to the pleasing wow! point of listening, seen that (I mean: heard).
So we are here down to the specific schematics i.e. combination of tubes, voltage, traffos etc etc.
Though, of course, some basics be obeyed. .. that's what we are cookin' of that old technology ))
Old 13th August 2017, 05:26 PM   #63
gabdx is offline gabdx  Canada
Using a row of devices with inverted signal can cancel 'something' on your scope like you can built perpetual motion devices, I am sure you can do both.
amplificateurslegrand.ca
Old 13th August 2017, 05:35 PM   #64
jazbo8 is offline jazbo8
jazbo8's Avatar
It's nothing like perpetual motion devices, inter-stage distortion cancellation techniques have been used since the 30's, perhaps even earlier...
Old 13th August 2017, 05:39 PM   #65
45's Avatar
Scope I meant a true analyzer, not even a crap sound card.
If you don't how to do it it doesn't mean that it is not possible. It is just not accessible to you or maybe you have done it by chance without being aware. Who knows...with the total confusion even about basic things you have in your mind eveything is possible!
Old 13th August 2017, 08:06 PM   #66
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Yes, for true believers.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th August 2017, 08:32 PM   #67
45's Avatar
Then can you explain how you can get 0.15% THD @1W and 3% @8W distortion from a 3x4P1LSE, without any other feedback? Scale the power down for your SE and see what you get. Do you get that THD at 0.33W and 2.66W. I don't think so.....And it is not the different OT.
Old 13th August 2017, 11:23 PM   #68
45's Avatar
Same identical amp with a (stand alone, very) linear voltage amp instead of ECC82 running at 242V/1.3mA with 100K plate resistance. Only other difference is plate voltage at 283V instead of 263V (that only brings more power).
Distortion never gets down to 0.15%. Even at 0.1W!
So I should believe that increasing the plate voltage by just 20V I will get such striking difference and/or the ECC82 is most linear device in any condition?
Old 13th August 2017, 11:47 PM   #69
Shef's Avatar
4P1L is specifically known for being super-linear triode-strapped, I do not get it why somebody turn its worthmost into the worthless. .. or we are talking about personal preferences then.
Old 13th August 2017, 11:51 PM   #70
45's Avatar
No better than others. Paralleling tubes makes linearity worse no matter how well they are matched. In fact 2x4P1L in parallel are not better than a 2A3. Here there are 3 in parallel.....
Cathode Bias confusionHide this!Advertise here!
Cathode Follower confusion Brit01 Tubes / Valves 27 20th July 2009 11:22 PM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 06:26 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 02:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
