Testing response....
Old 28th March 2004, 03:42 PM   #11
audiobot is offline audiobot  United States
Default time domain
This may be useful for understanding square wave analysis.
Time Domain Audio Measurements
Michael
Old 28th March 2004, 04:28 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Don't trust anything!
Yes, I should also have said don't trust your meter! Most <100 DVMs measure AC very poorly, whereas older equipment based on moving coil meters can be quite good. The AVO8 is useable to 15kHz. My (second-hand) Levell microvoltmeter is -3dB at 3MHz, and I used to have an ancient Marconi meter that was flat (-0.1dB) to 50MHz.
Don't forget that a 20MHz oscilloscope means -3dB at 20MHz.
You really need to know the limitations of your test gear.
To be fair, measuring noise is a very tough test, and it is perfectly possible for two meters to give different (legitimate) readings.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 28th March 2004, 05:03 PM   #13
stormy is offline stormy  United Kingdom
Default Re: time domain
Michael
thanx for posting this link, it ilustrates some good examples,
and saves me making a fool of myself in paintshop hehe
i hate paintshop :0)
Regards stormy
Old 28th March 2004, 05:24 PM   #14
Bryan is offline Bryan  United States
Thanks Guys!
Dont take life too seriously, you will never get out alive!
Old 28th March 2004, 06:16 PM   #15
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: Don't trust anything!
Not necessarily. I seem to remember my 475 is rated -1dB at 200MHz...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 28th March 2004, 11:20 PM   #16
EC8010's Avatar
Well, I don't have a manual for a 475, but the definition of bandwidth is -3dB.
Old 29th March 2004, 03:13 AM   #17
Sch3mat1c's Avatar
In general, if not specified. I could spec my amplifiers at 5Hz to 200kHz if I wanted, but it would be +1dB/-20dB in reality. MOST BW specs have variation at -1.5, -3 or -6dB (and little care towards any rises).
Lemme see...ok. Manual seems to imply -3dB point for BW (in any position).
Tim
Old 29th March 2004, 06:47 PM   #18
richwalters is offline richwalters
richwalters's Avatar
Hi there..... I've enclosed some links for those who need volts/dBu's/dBm's clarifying:
Starting out in test ? get hold of this lot......
At www.sowter.co.uk ........ scroll down to Decibels:
www.rane.com/note145.html
www.jimprice.com/prosound/db.html
learn and memorise the lot.....
rich
Old 29th March 2004, 06:53 PM   #19
Apol's site should read www.sowter.co.uk
Testing response....Hide this!Advertise here!
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 11:39 AM
Transient Response Testing cm961 Multi-Way 37 22nd March 2004 10:57 AM
just testing kmfdm_mdfmk Introductions 2 4th May 2002 08:18 PM
Copyright ©1999-2017 diyAudio
