Heater To Cathode Potential
Old 26th March 2004, 07:19 PM   #1
Bryan is offline Bryan  United States
Default Heater To Cathode Potential
Hey Guys,
Some general questions.....
With respect to Heater to Cathode Potential, what are the general rules of thumb.
Specifically, when does one need to raise the reference voltage of the heater above ground?
DHT vs IDHT?
AC vs DC?
What are the physical and sonic differences?
Thanks,
Bryan
Dont take life too seriously, you will never get out alive!
Old 26th March 2004, 08:42 PM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
A DHT heater is the cathode, so they are at the same potential. In an autobias ( cathode bias) DHT amp, the cathode resistor lifts the heater /cathode above ground. DC is recommended for a heater supply for hum reduction. Do not ground the heater supply!
For IDHT like 6SL7, 6SN7, there are heater to cathode maximums that must be observed when using circuits like SRPP, cathode follower. The numbers can be found in the data sheets for each. This can be achieved by using a reference voltage from the B+ and attaching this to the floating heater winding.
Old 26th March 2004, 09:03 PM   #3
metebalci is offline metebalci  Turkey
I did not understand this. With a floating cathode, how could you measure plate potential ? I will be appreciated if you explain it.
MB
Old 26th March 2004, 09:26 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
As ShiFty implies, if you were to ground the heater of a directly heated valve using cathode bias, you would be short-circuiting the cathode bias resistor, which would cause unrestricted current flow, upset the operating point, and possibly destroy the valve. Not a good idea.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th March 2004, 09:33 PM   #5
OK. Sorry, I just misunderstood. Thanks...
MB
Old 29th March 2004, 10:27 PM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
With totem pole type circuits it's easier to use twin triodes where top and bottom share the same enveloppe.
It makes it easier to bias the heater close to cathode potential that way.
Ideally heater and cathode should be at the same potential to avoid secondary emission from either one of them.
Frank
Old 29th March 2004, 10:37 PM   #7
Frank,
This being said, would I get any benefit from raising the heater potential in my 12B4A linestage. Currently it is sitting at a humble "0" volts.
Thanks,
Bryan
Old 29th March 2004, 10:55 PM   #8
fdegrove's Avatar
Thinking right but writing wrong....
I mean the top triodes being the same tube and the bottom a different one.
I realise the quotation can be confusing.
Bryan,
How's that? Is the cathode grounded?
If it is it can't emit anyway so you're safe.
Frank
Old 29th March 2004, 11:03 PM   #9
thoriated is offline thoriated  United States
Hi, Frank -
Do you know how bad secondary emission can get in what would be considered a 'good' miniature tube with a heater/cathode potential up to 100VDC over its lifespan?
This may impact how I configure the driver stage in my hybrid amp. If as a voltage/current gain stage, its cathode will be sitting nearly two hundred volts below ground, so I'll probably split the cathode potential halfway between that and ground, but I'm afraid that secondary emission might then deteriorate my dc offset stability.
Thanks in advance for any input.
-thoriated
Old 29th March 2004, 11:16 PM   #10
Frank,
Let me clarify.
The cathode is at approximately +9volts. The heater is referenced to ground. The anode is at about 100V.
Sorry about the confusion....
Heater To Cathode PotentialHide this!Advertise here!
Heater-Cathode Voltage bobbyq Tubes / Valves 11 11th August 2009 06:45 PM
Cathode-heater leakage Johan Potgieter Tubes / Valves 18 2nd March 2009 11:05 PM
Tie cathode to heater?? Klimon Tubes / Valves 17 19th May 2007 11:02 PM
heater/cathode query kianbach Tubes / Valves 5 23rd August 2005 10:37 PM
