#11 | ||
diyAudio Senior Member
However, if we were to cross the limits stated by the manufacturer, or you have a somewhat dodgy tube where the heater is at some point too close to the cathode sleeve, we risk a sticky heater and that can give us a very nasty bang. Inbetween, before it actually sticks, you may experience HF oscillations capable of killing your amps, tweeters and drive all pets from the room. Whether your hearing is good or not so good, this one won't pass unnoticed, believe me. Quote:
The same would apply as if it was above ground, i.e. positive, so the same precautions should be taken. As an example and regardless of max. heater to cathode voltage diffs. if the cathode has a potential diff. of 100V with respect to the heater I'd bias the heater upwards so the final diff. equal 0 volts. This is the theoretically ideal situation according to the Philips engineers. Cheers,
Frank |
#12 | |
F = +12.6V (as an example) A = Anode, don't play. All voltages measured with respect to true 0 volt; ground. Heater is grounded at one end, the negative leg. So the heater is 3.6V high with respect to C. No problem whatsoever. Don't go paranoid over this secondary emission, a few volts aren't going to start an electron war inside the tube. I was just crossing the Ts and dotting the I's, this is much more important with CRTs and labtests than I'd imagine it to be for audio purposes anyway. Cheers,
Frank |
#13 | |
#14 | |
Emission starts to occur at 30V potential difference, do you happen to have a diagram of the cct for us to look at? Cheers,
Frank |
#15 |
Hi, Frank -
This is probably more or less how it would look (I am using the driver as an inverted gain stage instead of a follower here) except that I'll be running the supply voltages somewhat lower, say +/- 170VDC instead of 200VDC. However, that still comes rather close to the maximum cathode heater ratings for the 6K11 with the heater potential centered between ground and the negative -170 V supply. Do you think secondary emission might adversely affect bias points over time? TIA. OTLs forever! |
#16 |
Since I can only guess the voltages on the cathodes, I suggest you build it as you want, measure all cathode to heater voltages on all sections of the 6K11 to start with. The problem you'll be facing is that the potentials are likely to vary rather wildly from one section to the next so we'll need to find some compromise. Sorry, I can't be of more help to you right now. Maybe someone with more insight into semi-conductor than i do can help you out on this one. Cheers,
Frank |
#17 |
diyAudio Moderator Emeritus
Thoriated: Looking at your diagram, you seemed to be in semiconductor mode when assigning values to your global feedback loop. You can cheerfully scale your resistors by a factor of at least ten, allowing you to use a much smaller capacitor than that 10uF you currently have.
You definitely need separate heater supplies for the input pair and the voltage amplifier. Expect DC problems if you don't.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#18 | |
Frank |
#19 |
Oh dear. That puts a rather large spanner in the works. I'll bet it's cheap, too.
#20 | |
1/2 a ECC82 like the EC92 is half a ECC81. Checking Duncan Amps.......yes, a 6C4. Cheers,
Frank |
| Heater-Cathode Voltage | bobbyq | Tubes / Valves | 11 | 11th August 2009 06:45 PM |
| Cathode-heater leakage | Johan Potgieter | Tubes / Valves | 18 | 2nd March 2009 11:05 PM |
| Tie cathode to heater?? | Klimon | Tubes / Valves | 17 | 19th May 2007 11:02 PM |
| heater/cathode query | kianbach | Tubes / Valves | 5 | 23rd August 2005 10:37 PM |
