diyAudio Sponsor
Old 26th March 2004, 06:41 PM   #1
dud_wity's Avatar
Send a message via ICQ to dud_wity
Default uneven wound 50w OT 2 ideas...?
amp the OT is not wound symmetrically from the center to the tips i get 45 ohm and 68 ohm.
2 options cross my mind..
1- pott the transformer again cos maybe it warmed up and the isolation melted..
2-using the OT without using the center tip maybe as class a amp?
can it be done?
thanks for the suggestions
David
when you drink bleach try not to stain your shirt
Old 26th March 2004, 06:54 PM   #2
SY's Avatar
Actually, this is very common in a lot of classic iron where the two sides are not wound bifilar. The side of the CT which is farther from the core will have a higher DC resistance for the same number of turns. If the AC balance at bass and midband is OK, I wouldn't sweat it.
At worst, you might have to do a bit of compensation on one side to stabilize feedback, generally a small cap between the CT and the lower resistance end. Check out the Eico HF87 schematic for an example of this. Dynaco used a cap (iirc, 390 pf) from the screen tap on that side back to the input stage.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th March 2004, 08:18 PM   #3
dud_wity's Avatar
Default the thing is...
the man i bought if from told me that the OT is gone...
when i took it home i checked it and found that the winding isn't broken not at the input nor on any of the outputs..
the only abnormality i found was the resistance ratio
i will connect it to a sine wave generator and spectrum analyzer and see the frequency response as well as trying to check from the input output voltage ratio and the output resistance terminal the resistance of the primary..
so you think there is no room for re potting the transformer?
only using feedback to fix the output ratio?
Old 26th March 2004, 11:28 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I doubt if anything is faulty with the transformer. There are two ways of achieving balanced resistances (ideal). Either you wind bifilar, or you use vertical sectioning, rather than horizontal, which means using a split bobbin, so that each PP section is identical. A short-circuited turn will be immediately apparent on an AC test as extremely poor performance.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th March 2004, 11:35 PM   #5
SY's Avatar
No, I wasn't clear, sorry. The output ratio may very well be fine. I was merely explaining why the DCRs might be different in a perfectly sound transformer. Which yours may well be; EC8010 summed up better than I could. My other suggestions were for ways of doing compensation for a lack of perfect AC balance at the extreme top end due to the winding method, not for fixing a faulty transformer.
If it is faulty, you need to rewind it- repotting won't help.
Old 26th March 2004, 11:53 PM   #6
EC8010's Avatar
Hello SY: I'd be interested to see the circuit of a commercial amplifier that owns up to needing to compensate for the poor winding balance in its output transformer...
It's frightening, but most output transformers are wound unbalanced.
Old 27th March 2004, 01:38 AM   #7
SY's Avatar
Take a gander at the Eico HF87 that I mentioned; the schematic from Photofacts is up on the web somewhere. And there's that unbalanced feedback cap in the ST-70 (the Dyna circuit); it's HF unbalance, not midband that's being compensated by the cap in both these commercial examples. The midband imbalances only seem to get taken care of in amateur designs, usually doing something like deliberately unbalancing the operating points of the output tubes, or in commercial amps with adjustable AC balance.
In the latter case, adjustment instructions typically call for minimizing output with a common-mode 60 Hz signal, which in effect compensates for any OPT imbalance (at least it does at 60 Hz).
Old 27th March 2004, 09:47 AM   #8
dud_wity's Avatar
Default thank you
here is the schematic of the eico amp if someone is interested.
i will tri the ac test at http://www.geofex.com/ampdbug/outtrans.htm
i hope i dont have internal shorts inside...
Old 27th March 2004, 11:57 AM   #9
SY's Avatar
Todah rabah!
The 470pF cap is the one I was talking about. Note the unbalance in the DCR. That notwithstanding, these output tranformers work superbly (I think they were sourced from Brooks).
Old 27th March 2004, 01:17 PM   #10
EC8010's Avatar
That Eico certainly is unbalanced. Interesting.
Transformer with uneven ac out geminni Solid State 6 1st February 2008 05:52 AM
Isobarik with uneven signals mashaffer Subwoofers 6 30th May 2006 08:47 PM
Uneven voltage on PS chipco3434 Power Supplies 11 22nd February 2006 02:10 PM
uneven output on my 206 carlos671 Digital Source 2 6th December 2005 03:10 PM
Page generated in 0.10927 seconds (81.92% PHP - 18.08% MySQL) with 11 queries
