ST70 Iron help
ST70 Iron help
Old 13th July 2017, 02:40 PM   #1
cygnus x1 is offline cygnus x1  United States
Default ST70 Iron help
Looking for recommendation for output iron for a Dynaco ST70 clone. While I would love lundahl or better, the funds aren't available. Between, Edcor, Triode Electronics, or Hammond what is the best choice...or another " low cost" option? Maybe someone is setting on something I can use?
Old 13th July 2017, 03:08 PM   #2
petertub is offline petertub  Sweden
triode, dynakitparts are two suppliers. That is if you aim for a st70
Other transformers will create something else then a st70 ( dynaco)
My home is at www.tubular-well.se
Old 13th July 2017, 03:54 PM   #3
Brinkman is offline Brinkman  United States
If you're sticking with the original driver circuit and power supply, you'll probably be fine with even the most inexpensive iron you can find. If you are using an upgraded driver board (vta or diytube) then I would consider ordering custom iron from Edcor.
I built a kit (using the stock iron) from dynakitparts.com about ten years back and wasn't really satisfied with the sound until I started upgrading the power supply and driver circuitry. I hear the triode electronics iron is of equal quality to that of dynakitparts.
Old 13th July 2017, 06:23 PM   #4
I was thinking of the VTA board, since it now has CCS and plan on an upgraded PS. Fixed bias. The Lundahl LL1633 was also a consideration. The Edor is the cheaper, where the Triode and Hammond are near the same price, and the Lundahl at the top...can't even consider the AM version. So not a strict clone of the 7199 Dynaco driver (even though I have an old board). I have to ask why "custom iron from Edcor"? I was looking at the Edcor CXPP60-4.2K with the multi tap output?
Old 14th July 2017, 11:12 AM   #5
zacster is offline zacster  United States
Why build a Dynaco clone? If you are spending the money on the iron anyway, build something better. And I'm saying this where an ST-70 is the basis for my amp. There is nothing original left except the transformers and chassis, and I wish I had a larger chassis so I could do more. I have the Curcio CCDA board in mine, except that he's no longer in the business apparently. Also, mine is running 6B4G output tubes. No quad cap, using 5U4 rectifier, no negative feedback, all in all, no longer much of a Dynaco.
I'm slowly accumulating parts to build an Amity, and I'll probably go all Lundahl myself, except that the Dynaco output transformers will be the first iteration since that's what I have. I'll probably use Genalex 300b and definitely a bigger chassis.
Old 15th July 2017, 02:01 PM   #6
This is for a secondary system, for the wife, so need it simple...CD, passive pre, EL34 based amp. May just do Edcor (but they say 6 wks) and VTA board. Rather build new than by a tired out old ST70 for $$$. People want way to much for an old one. Way back when, I got one for $75 at a garage sale. Even old console tube amps, people want $200+ now days.
Old 15th July 2017, 03:50 PM   #7
kevinkr's Avatar
ST70 Iron help
Early in the 1980s I got a number of ST-70, MKII, MKIII and MKIV for chump change. People could not get rid of them fast enough. Some people even gave them to me, knowing full well I was going to fix them up and resell them (for chump change). My then employer was clearing out a large inventory of vacuum tubes at the time and was going to throw them all out (write off), however the senior management somehow approved throwing them into the trunk of my car instead! (They had to sign the material disposition forms so they could be removed from the building.) They thought it was amusing that I was fixing up old amps and keeping them out of landfills. They didn't pay very well so this helped keep the lights on. (dawn of my career)
It is amazing how much these relatively mediocre amps sell for these days.
Interestingly those who owned ST-35s wanted much more money for them that is if they were willing to sell them at all. I never got any, although I did get a number of SCA-35s.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th July 2017, 02:28 PM   #8
Yep, the only tube amp is was ever given was a SCA-35 and old Gromes. Paid $5 for a WM4, second one was $13. Best deal I ever got, I purchased two HK Citation II for $50 each, when I worked at a stereo shop and the owner would not take in on trade, because they did not have tubes. Made the mistake of selling them, now they are $$$$.
ST70 Iron helpHide this!Advertise here!
Help with Eico ST70 devilsindetails Tubes / Valves 14 2nd May 2015 05:21 AM
ST70 iron recommendations please zigzagflux Tubes / Valves 23 2nd February 2012 12:38 PM
EL34 for ST70 MichaelK Tubes / Valves 4 29th March 2010 06:40 AM
ST70 clones hfh Tubes / Valves 8 12th August 2009 02:04 AM
Need help with my ST70 JayH3 Tubes / Valves 7 23rd May 2008 01:56 AM
