12AX7 SE baby amp
12AX7 SE baby amp
Old 19th June 2017, 11:48 PM   #1
vizion is offline vizion  United States
Default 12AX7 SE baby amp
Has anyone built a 12ax7 SE amp ? I wonder how many milliwatts it can produce.
Old 20th June 2017, 12:50 AM   #2
kevinkr's Avatar
12AX7 SE baby amp
12AX7 plate resistance is too high for practical output transformers. (EAR did do a massively parallel PP amp with 12AX7A some time ago.)
Consider the 6CG7/6FQ7 or 12AU7A for a flea power SE if this is really the way you want to go.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 20th June 2017, 01:05 AM   #3
PRR is offline PRR  United States
PRR's Avatar
As Kevin says, you can't make a wide-band audio transformer with enough impedance to get real power out of the 12AX7 high impedance.
I plotted 22K, the reverb transformer sold for Fenders using a 12AT7 reverb driver. Say 65mW. A bit more depending how you feel about max plate voltage. (I'm sure 400V is not instant death, but also not a lot more power.)
Old 20th June 2017, 05:30 AM   #4
thanks guys
Old 20th June 2017, 03:38 PM   #5
kodabmx is offline kodabmx  Canada
The 6N*P except 6N2 are good candidates, too.
Old 21st June 2017, 02:14 PM   #6
Ketje is offline Ketje  Belgium
Ketje's Avatar
How about a serial SE
Mona
Old 27th June 2017, 03:22 PM   #7
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
12AX7 SE baby amp
6SN7, 12AU7, or 6DJ8 would be much better candidates... I can squeeze around a half watt out of a 6SN7 in SE.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
12AX7 SE baby ampHide this!Advertise here!
EL84 Amp - Baby Huey gingertube Tubes / Valves 2078 13th June 2018 09:32 AM
el84/12ax7 se schematic needed! tubo Tubes / Valves 9 28th February 2013 02:21 AM
My new baby amp suzyj Solid State 21 19th May 2009 02:11 PM
SE 6C33C-B ; preview of a new Baby Alain Dupont Tubes / Valves 51 27th September 2006 01:15 PM
