About high voltage regulated power supplies
Old 24th March 2004, 07:33 AM   #1
wd40 is offline wd40  China
wd40's Avatar
Default About high voltage regulated power supplies
Hi all:
About high voltage regulated power supplies.There is any very good proposal .Thank!
My english is very poor.
Old 24th March 2004, 07:43 AM   #2
Layberinthius is offline Layberinthius  Antarctica
http://members.aol.com/sbench/reg1.html
http://members.aol.com/sbench/reg2.html
http://www.thermionic.org/types.html
http://www.electronixandmore.com/project/2.html
Check those out.
While this is unbased concern, I'm interested how they add to noise in my shiny clean B+
For an amplifier to use these it would have to be a very low powered one.
Old 24th March 2004, 08:12 AM   #3
wd40's Avatar
Default Hi Layberinthius
I'm looking,Thank very much.When higher accuracy?
Old 24th March 2004, 11:07 AM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
There's no point in using a regulator that's adding noise to the B+, IME a well designed one shouldn't. Quite to the contrary.
What voltages and currents are you looking for?
Series or shunt regs? How "accurate" do you want it to be?
Frank
Old 25th March 2004, 03:16 AM   #5
wd40's Avatar
Default Hi fdegrove
I am that the use is living on the preamp°£
About high voltage regulated power suppliesHide this!Advertise here!
Lost Thread-High VOltage Regulated Power Supply LinuksGuru Tubes / Valves 2 21st June 2009 01:48 AM
high performance regulated supplies for power amps jez Solid State 14 5th January 2004 03:22 PM
High voltage metal can oil capacitors for tube amp power supplies CCOZGO40 Swap Meet 1 3rd November 2002 08:10 PM
high-voltage regulated dual power supply zzz Solid State 1 17th September 2002 01:15 AM
FS: (2) 28 VDC 11 AMP regulated power supplies. FEThead Swap Meet 1 2nd May 2002 04:18 PM
Copyright ©1999-2017 diyAudio
