diyAudio Sponsor
Old 25th March 2004, 08:00 PM   #21
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hmm...may be true, may not be. We'll have to wait and see!
Since the rectified HF signal is essentially AVC, you could tap into it and bias it for electronic volume control, couple in some audio (plus a shaping circuit for log/exp. AVC response) for compression or expansion, etc. Hmmm...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 25th March 2004, 08:17 PM   #22
smoking-amp's Avatar
Default different perspective
Chapter 2.5 .1.2.6.1.4.2.1...
Thinking about this a little more, I think one could look at the gain control feedback loop (in the gain multiplier designs, including the dither design) as a simple classical control system that is trying to maintain a setpoint versus external interfering influence (the input signal excercising different operating points with slightly different gains). So what is needed is critical damping in the gain control loop to minimize the residual effects of control level changes. Also, the correct gain to maintain accurate setpoint.
So distortion correction effects would still have some trailing influence somewhat like in conventional NFB loops, but I think this would be a very small effect for a well designed amplifier due to the small level of change of gain except near saturation. So the (multiplier) control level is hardly changing for large signal variations. Also, the effect of a critically damped bounce in the control level may simply allow some uncorrected distortion thru rather than generating new higher harmonics, but would need to simulate or test this. Generally though, for a control system that is fast compared to the stimulus signal, the effect of changing input is to just generate a small slew related lag error in the control level, and this should not be a problem. I think! (Darn, where's that control system book from 30 years ago?)
Don
Ohms Law V = I R
Old 12th November 2004, 10:02 AM   #23
Prune is offline Prune  Canada
Account Disabled
I am curious, what is the problem with simply taking into account the whole signal path (DAC->Speaker&RoomReflections) distortion and digitally predistorting the signal?
Old 12th November 2004, 02:54 PM   #24
Sch3mat1c's Avatar
Nothing, but it doesn't adapt to *anything*. It'll sound good with your head positioned in exactly the correct spot. Complicated to get a good measurement anyway.
Tim
Old 12th November 2004, 11:32 PM   #25
Account Disabled
So? Just use head-tracking tehcnology.
Old 13th November 2004, 03:24 AM   #26
Sch3mat1c's Avatar
Y'mean headphones? :P
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
Re: New error correction amp mefistofelez Solid State 12 7th October 2010 06:55 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Question- post filter feedback error correction? darkfenriz Class D 11 13th June 2006 10:31 PM
Page generated in 0.08620 seconds (75.22% PHP - 24.78% MySQL) with 11 queries
