Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
how important is good power supply for B+?
is battery the best? can I use transistored rectifier for B+? how can I measure a quality of rectifier? sorry, I'm a newbie.....
too much is just enough |
#2 |
On Hiatus
How important is a tire?
It's all a matter of what you're trying to do and what your critereon of "best" is. What's perfectly adequate for one situation or application may not be in another. Can you be a bit more specific?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is." |
#3 | |
o.k. sorry..... is nessesarry to use choke in PS for common CF or can I use transistored version? and....how do you know, when DC is enough DC to avoid hum? I'm learning....
#4 |
On Hiatus
OK, we're getting closer now. A cathode follower has good power supply rejection, so the B+ quality isn't hyper-critical. How good is good enough? From an engineering perspective (as opposed to unsubstatiated anecdote), it's good enough when the noise/hum/ripple is low enough not to degrade the output signal at a level higher than the desired signal to noise ratio. This should take into account the PS rejection of the CF, which makes things easy.
For example, let's say you're designing a CF to handle signals in the 1V range, and you want the S/N to be better than -80 dB with respect to the 1V reference level. That means that any noise components due to the supply should be 80 dB below 1V. If the CF has a PS rejection ratio of 40 dB, that means that the supply's hum and noise should be 80-40 = 40 dB below 1V, or 10 millivolts for this example.
Thread | Thread Starter | Forum | Replies | Last Post |
Robust Power Supply PCB suited to hi-quality amplifiers | RyanW | Solid State | 58 | 17th April 2008 12:34 PM |
Need high quality prebuilt power supply for DAC | zhai | Digital Source | 9 | 5th December 2006 12:47 PM |
UCD AD180 + High Quality power supply | SEIJI | Swap Meet | 1 | 10th September 2006 03:06 PM |
UcD HG power supply sound quality? | ghemink | Class D | 6 | 4th August 2005 04:01 PM |
New To Site? | Need Help? |
