Gassy Tube
Gassy Tube
Old 22nd March 2004, 01:37 PM   #1
morfeas is offline morfeas  Greece
Default Gassy Tube
This is how it looks when you let some air in.
Old 22nd March 2004, 01:41 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
WOW!
What kind of tube? That's spectacular!
Frank
Old 22nd March 2004, 01:59 PM   #3
ECC81
Can't imagine how it would look with a big one.
Old 22nd March 2004, 02:56 PM   #4
Layberinthius is offline Layberinthius  Antarctica
It looks beauutiful!!! How did you get the air out increcementally?
Was there a hairline crack to begin with eh?
If only they sold em like this and they operated in normal parameters
Old 22nd March 2004, 03:03 PM   #5
redwine1118 is offline redwine1118  Hong Kong
Send a message via Yahoo to redwine1118
HI,
Just like the emission color for a mercury vapour rectifier (RCA 83)
Red
Old 22nd March 2004, 06:18 PM   #6
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hehe, I've had a gassy 12AT7. A special thing about this type on my tube tester is I can arrange the voltages so I get electron emission through the holes in the plates and get some blue spots on the glass.. well this thing not only had blue spots but purple trails showing every electron moving!
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 22nd March 2004, 08:39 PM   #7
I did bend the pins just a little to get better contact in a loose socket. I think with heating up the pin-glass seal broke letting just a zip of air inside. No cracks on the glass.
Still have the tube around and the getter looks fine.
Have done this (bending the pins) many times with other brands and had no problem.
The most spectacular was the arcs inside. Amazing view.
Old 22nd March 2004, 11:50 PM   #8
Sch3mat1c's Avatar
If there was any crack whatsoever it would continue to leak. And tubes tend not to be self-healing when it comes to vacuum, so that's odd..
Tim
Old 22nd March 2004, 11:53 PM   #9
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
That's not air but a polluted cathode surface that somehow releases it's ions all of a sudden.
If it were a leak it would have killed the tube within a split second.
Either way it's quite unique...
Frank
Old 23rd March 2004, 04:32 AM   #10
Looks like something out of Star Trek or inside a star
That blue glow gets me thinkin...
Stop me Frank!!! :P
Has anyone seen a supply of Blue Neon 'power-switch' indicator lamps? or a 'tuning-indicator' Blue version?
I'm sure if there were they'd sell like hot-cakes, maybe someone with influence can whisper in Svetlana/Sylvania's ear about making a few volume level indicators with blue glow?
Gassy TubeHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
Blue glow in tube. Is the tube dead or not? Pentium100 Tubes / Valves 37 22nd October 2009 07:45 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
