| diyAudio Sponsor | ||
diyAudio Moderator Emeritus
Hi all,
Wanted to ask the tube expert about this schematic. I have problem with PS, so I wanted the tube section works in lower voltage. How much lower the tube can go? I wanted the tube to be able to work in +/-2V p-p sinusoidal without defect or clipping. Will it go to +/-15V for the tube? |
#2 | |
diyAudio Senior Member
With an effective B+ of 30V I'd expect some distortion with the 6DJ8/ECC88. What you can try is use a 6GM8/ECC86 instead or otherwise explain us what the problem is you're experiencing with the GC. Cheers,
Frank |
#3 | |||
Hi, fdgrove,
Why I ask the question? I wanted to built this design into 2 possibilities. First the tubed gainclone. It is ok with the supply, since it is the same value. Second to built a tubed preamp (replacing the gainclone with opamp). In this tubed preamp, the opamp needs only +/-15V, so to make things simple, could the tube take the same +/-15V also (or I will need other supply just for the tubes) |
#4 | |
Have you considered using a voltage doubler as a powersupply? It's not the best there is but short of adding another xformer it might save you a lot of hassle if your current xformer can handle it. Also, have you put your question to mr Rasmussen himself? Cheers,
Frank |
#5 |
Hi, fdegrove,
I will ask a question. But I take your answer is Higher, instead of Lower. I'm not familiar with tubes. In this cathode follower, is the input signal have the same height as the output signal (as buffer) or it will have somekind of magnification? |
#6 | |
I noticed you put the question to mr Rasmussen already. What you need to work with tubes is an understanding of loadlines. It's a little beyond the needs of what you're doing now but if you plan to work with tubes in the future you'll find it quite interesting. Hope it was of help,
Frank |
#7 |
my last experiments with ecc88 show good behavior with power supply of +/-19V, FET cs with 2mA and Va ca 30V. (grid is about -10V). Maximum AC voltage thru buffer was ca 5Vpp. Standard ECC88 buffer circuit (grid on 0VDC) can't work good on +/-15V PS, IMHO. Regards |
#8 | ||
HI
ecc88, e88cc,6922, pcc88 , 6dj8 etc. Quote:
voltage. The following cir, for instance, shows high dist. at 2Vrms ( 0.5% about) but , irrespective to this, it sounds good. Bye Federico |
#9 | |
Hi, Moamps,
Hi, Federico, I'm also confused with your drawing. The supply is floating and where is the output is taken. What does the THD of 0.5% behave, if we use big rating power amp? Will it produce hiss, or distorted sound, or something else, or nothing? |
#10 | |
Hi, schematic looks similar to second schematic on this site: http://www.diyzone.net/diy/referenc...dj8buffer_2.htm. Cathode is on ca -10V potential. Supply is +/-19V. Regards |
| Recommend me a warm, smooth sounding 6922, 6DJ8, ECC88 or equivalent | gaplessophile | Tubes / Valves | 36 | 3rd July 2009 07:24 AM |
| ECC88 Help | rhysh | Tubes / Valves | 2 | 1st December 2008 10:52 PM |
| 6n1p (6922/ecc88) Nos | Mayday | Swap Meet | 0 | 2nd January 2007 12:14 AM |
| WTB: 6DJ8 / ECC88 / 6922 Tubes | mrdon | Swap Meet | 0 | 6th September 2005 09:58 PM |
| What to do with ECC88's? | Simpleton | Tubes / Valves | 15 | 16th June 2005 08:39 AM |
| Page generated in 0.11973 seconds (79.75% PHP - 20.25% MySQL) with 11 queries |
