Odd issue with first turn-on - diyAudio
Old 22nd April 2017, 03:24 PM   #1
kendt is offline kendt  Canada
Default Odd issue with first turn-on
I wondered if anyone might be able to assist with a problem in my new build. When I first turned it on to test voltages after a few seconds i started to hear a clicking sound and noticed some minor sparking between some of the pins of the 6p15p output tube. Its not any serious zaps just very light. I was thinking that maybe the bypass cap might be funky but i thought someone else has encountered this and could shed some light on it before I start pulling parts out.
Old 22nd April 2017, 04:02 PM   #2
Ketje is offline Ketje  Belgium
Ketje's Avatar
SE amp without speaker connected and motorboating ?
Mona
Old 22nd April 2017, 05:15 PM   #3
well i have had motor boating with other builds and never had sparks or clicking sounds. I tried reversing the tubes but it didnt change.
Old 22nd April 2017, 05:54 PM   #4
Mona
Ok well it appears you were right.I connected speakers and the sparking went away.It is motorboating but also making some screetchy crackling noise. Very frustrating indeed.
Old 22nd April 2017, 06:22 PM   #5
nigelwright7557's Avatar
Sounds like positive feedback.
Is the feedback connected in the correct phase ?
You can try reversing feedback + and - to see if that is the problem.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 22nd April 2017, 06:22 PM   #6
Ketje's Avatar
Well, sparks can make short circuits within the OPT.Also damage isolation between pins.Perhaps a capacitor over the primary of the transformer didn't survive.
Mona
Old 22nd April 2017, 07:15 PM   #7
DF96 is offline DF96  England
Could be HF parasitic oscillation (possibly at OPT HF resonance?) due to lack of damping from speaker. You are fortunate that you did not blow the OPT. Never, ever, run a valve amp with no load attached.
Old 22nd April 2017, 08:26 PM   #8
Thanks.Ive done it in the past and never had an issue.Got lucky I guess. I moved the ps ground to a point on the chassis and everything settled down all except for a very slight hum.
Old 22nd April 2017, 08:36 PM   #9
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
NEVER EVER POWER ON A TUBE AMP WITHOUT LOAD!!!
It is possible to protect output transformers in PP amps by reverse-parallel to tubes damper diodes, but you can't protect SE transformers so simply!
The Devil is not so terrible as his math model is!
Old 22nd April 2017, 08:38 PM   #10
AquaTarkus's Avatar
Originally Posted by DF96 View Post
.Never, ever, run a valve amp with no load attached.
Like he said, *NEVER EVER*. Yes, you've been extremely lucky so far.
Sent from my phone with Tapatalk. Please excuse any typpos.
Soldering Help - Odd Issue robbbby Construction Tips 10 9th April 2016 11:17 AM
odd punch 200.2 issue spooney Car Audio 16 17th October 2009 02:46 AM
Odd toroid and odd issue...help...please!! mpmarino Parts 31 2nd January 2009 11:58 PM
Behringer MX9000 - odd power issue Deekaph Power Supplies 23 11th March 2008 04:16 PM
I have an odd transformer issue (want to build the gainclone) Jerry Parker Chip Amps 9 22nd October 2003 12:37 AM
Copyright 1999-2017 diyAudio
