Old 25th March 2004, 12:23 AM   #21
diyAudio Senior Member
fdegrove's Avatar
Wayne,
You could try a 1N4007 in series with a dropping resistor in place of the choke.
Even just a diode in series with the PS and followed by some capacitance will do a good job already.
I once put the question here on the forum as I had a 1N4007 in the PSU as described and had completely forgotten why it was there.
Nobody seemed to know the answer but it turned out that this trick is rather popular with the guitar amp guys.
Frank
Old 25th March 2004, 01:03 PM   #22
cogsncogs's Avatar
Talking Poor man's regulator
Hi Frank,
I did that back when I was teenager to my amp without having seen that done. Just by playing around and trying to use logical deduction. And lo and behold I read about it in the glass shards dept. of Glass Audio magazine! I thought to myself, Hey I invented that! Of course I know better!
Wayne
Old 25th March 2004, 04:39 PM   #23
cogsncogs's Avatar
Thumbs up LOW bass
Hi arnoldc,
the amp i prototyped got a very good midrange in which i was surprised myself. however, it definitely is lacking in the bass department, more so low bass. it is like it's there but it isn't. like running out of steam if i may say.
Well your output iron has a great influence in the bass department, as does a lot of other things. How much feedback if any, coupling caps, and any other RC time constants etc. I wouldn't order new iron just yet.
Do you have a schematic of you're current set up so I can have a look at it? That would help a lot. You can zip it up and email it to me if you like. I could email you a schem of mine.
5k opt is a good choice. 6k6 opt will give you slightly less power and lower distortion. Depends a lot on your operating point. Core saturation could be your problem and here again this is where a scope comes in handy. It's OPT design dependent.
I hope we can help you here. Of course we all could use use a little help now and then!
i'd appreciate if you could share your experience on this having built that magnificent PP amp of yours.
Flattery will get you anywhere!
Wayne
Another Power Supply Question soundbadger Tubes / Valves 12 10th October 2007 12:29 AM
a question of tube behaviour g-banjo Tubes / Valves 2 14th November 2005 08:05 AM
NEED help power supply question. jleaman Parts 12 30th September 2003 01:12 AM
power supply question Mach_Y Solid State 7 14th April 2003 08:13 AM
Power supply question Fossil Solid State 5 3rd October 2001 09:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
