Mod 805 based amp without anode cap
Old 21st April 2017, 05:54 PM   #1
ChuckBanger is offline ChuckBanger
Default Mod 805 based amp without anode cap
My amp uses 805 tubes without anode caps. I cant find any data sheet for 805 without anode cap. But if i read this sheet correctly i only need to take the connection to the pin left of bayonet pin and attach that on the anode cap?
But this sheet makes me confused. The picture on the first page where the pins are numbered and the picture on the secound page dont match...
Old 21st April 2017, 06:13 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
One is a bottom view, the other is a top view.
Yes, you need the anode caps for the 805 per the drawings or you have no connection to the anode (Plate).
Are you sure your amp is running 805s?
Pictures of your amp?
Schematic?
If there are no dogs in Heaven, I don't want to go there.
Old 21st April 2017, 06:34 PM   #3
You are maybe right. I think it is 805a tubes not 805.
Its these tubes i think: http://www.grantfidelity.com/images/RZ/805A-T.jpg
And I whant to use these tubes: http://grantfidelity.com/site/files/805T-spec.jpg
This is my tube: https://www.dropbox.com/s/g2oca9dqsu...20.12.jpg?dl=0
Old 22nd April 2017, 11:09 PM   #4
6A3sUMMER is offline 6A3sUMMER  United States
It appears that the "805a" is a "Modern Botique" version of the old RCA 805.
Just something companies do to capture a share of the market (partly because it is
more convenient too).
That is a little like when years ago Svetlana made "811" tubes that took the plate cap off the top, and connected the plate to one of the 4 pins below (811-3, 811-10, etc.).
I bet that the plate on your "805" tubes are connected to pin 3.
You will have to pull apart the amp, and see if the 805 filament power is connected to pins 2 and 4; and if the output transformer primary is connected to pin 3, and the driver tube (probably from a cathode, or from an interstage transformer secondary) is connected to the 805a grid pin 1.
Mod 805 based amp without anode capHide this!Advertise here!
Dimensions for anode cap sizes? leadbelly Tubes / Valves 8 28th August 2016 10:02 AM
211/845 tubes in a 805 based amp ? Legis Tubes / Valves 12 6th May 2015 05:24 PM
Anode Cap Question sgerus Tubes / Valves 6 7th September 2007 06:00 PM
Re-attaching anode cap to 805 or 811A tube Jim Ricketts Tubes / Valves 5 7th June 2006 02:39 PM
High Power 805 Triode based amplifier BlackUnikorn Tubes / Valves 3 7th June 2004 08:44 AM
Copyright ©1999-2017 diyAudio
