Solid state current limiters instead of screen resistors
Old 19th April 2017, 08:01 PM   #1
zintolo is offline zintolo  Italy
Default Solid state current limiters instead of screen resistors
Hi all,
I'm currently reinventing the weel with different point of view on well known stuff.
I would like to ask if anybody has ever used transistors as current limiters for screen grids, instead of the classical resistors.
The reason is that I like the dynamic that the amp has without screen resistors, but at the same time the tubes are really prone to blow.
So I thought about using current limiters to let the screen to see a very low resistance until the critical current is reached, then it is limited.
This should be a win-win solution, but evil is in details, and what I don't know is if anyone else has done similar tests, and what is the sonic reaction on transitories.
Has anyone some experience on it?
Thanks in advance for your help.
Old 19th April 2017, 08:51 PM   #2
sser2 is offline sser2  United States
I guess the goal here is to limit screen dissipation power. While current limiter will achieve this, current limiting will cause screen voltage to drop. For best results, screen voltage in pentode connection should be kept constant.
With Ug2<<Ua, neither screen voltage regulation, nor screen dissipation is a problem, and screen power waste is minimized.
Old 19th April 2017, 09:04 PM   #3
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
I did it once. I thought it would be good protection for the output tubes in case of gross overload. I don't think there is any harm if you choose a screen current limit that won't be hit in normal operation.
One thing I did notice was that when I did a gross overload test, the waveform did look like a smoothed out volcano peak due to the screen voltage drop during current limiting. There was a point reached where if I drove the output tube harder, output would start to fall, then as the input signal reversed direction, output would begin to go back up, then back down. This was an open-loop amp but if this behavior were in a feedback loop, things might get weird/ugly.
I didn't think it was a problem for me in this open-loop amp because those were ear-bleeding power levels that would never be reached in normal practice but it is something to be aware of.
My Blog: http://tubeswithatwist.blogspot.com/
Old 19th April 2017, 09:13 PM   #4
I played time ago an old Marshall 1959 without screen resistors and the feel was incredible. Due to a long tour, the player asked to install screen resistors, beause he was facing alot of blows on his EL34s. Done, then the feel was completly different. Removed again and back again the nice feel.
Done on other amps, and the feeling is the same, but also the drawbacks.
Old 19th April 2017, 09:28 PM   #5
Current reduced, series resistance increased, g2 voltage reeduced, gain reduced. Clear.
With the right RC constants this can be musical in a tube amp. It can introduce compression. Have you tried to reduce the point where the current limiter starts working? This could become an interesting control.
Thanks, well noted.
Old 19th April 2017, 09:46 PM   #6
DF96 is offline DF96  England
If this question is about guitar amps then it ought to be in the other forum.
Old 19th April 2017, 09:50 PM   #7
The idea started from a guitar amp, but the concept has not to be limited to that.
I personally would prefer to have more general feedback on this topic.
Old 20th April 2017, 12:50 AM   #8
I did not experiment much with it. I simply noted the waveform shape. Unfortunately, I didn't take a picture. My circuit had no RC time constants so recovered instantaneously.
Old 20th April 2017, 02:24 AM   #9
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I have tried strict current limiting on the screen supply of sweep tube amps since their screen grids are their weak point. A low enough current limit to avoid glowing grid syndrome on a cranked amp is audible on music with strong transients. This may not be the case with the usual audio tubes like 6L6GC, KT88, and EL34. I didn't try it with them.
Some type of VI limiting is required with screen driven sweep tubes to prevent catastrophic amp failure when the screen grid gets hot enough to emit electrons and cause a screen to plate tube arc, destroying the tube and most of the driver circuitry. I have been experimenting with something like what I describe below, only microprocessor controlled.
I have a little 4 watt push pull guitar amp that I designed and built. The output tubes are 32ET5's, common in the last generation of tube table radios. Their screen current goes up sharply as you slam the tubes into clipping, and this behavior is common with most tubes. After melting an output tube, I simply stuck a 2.7K (a 4 watt amp remember) resistor in series with the screen supply, and wired the entire preamp supply on the screen side of that resistor, for improved sag induced touch sensitivity and some degree of self limiting. Amp sounds great for a small practice amp.....done.
Some time later I wired two orange LED's and a 1K resistor in series and connected that string across the 2.7 K screen supply resistor. I mounted the LED's under the output tube sockets to create the illusion that the output tubes are melting when the amp is hammered hard. Cool effect, done.
It seems to me that the LED's could be attached to an LDR which could be used to shunt some of the drive signal to create a limiter device. I believe Wavebourne has done this on one of his stereo amps.
Some delay, or integration could be employed to allow quick transients to pass unlimited as to avoid interfering with the sound, but integrate up the long term screen input and reduce the average drive level or impose more strict limiting, before screen meltdown happens.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 20th April 2017, 03:15 AM   #10
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Then you will kill dynamics because screen current will be abruptly chopped all the time, same as poorly adjusted short protection in SS amps .... ugh !!!!!!
While a resistor has constant resistance and will be fr less intrusive.
What you need is a regulated screen supply, like sser2 said.
If you lower typical guitar amp abuse level voltage to what the datasheet suggests, say 350V for screens instead of tying it up to >>400V plate voltage, they will not suffer and being constant voltage, they won´t hurt dyamics.
I also built power amps using 6DQ6 sweep tubes, real robust and powerful but needed screens strictly kept at +150V , whuch was easy to do.
Way back then (we are talking the 70`s), no Mosfets available but I used high voltage TV sweep transistors, worked like a charm.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Solid state current limiters instead of screen resistorsHide this!Advertise here!
current rating for chokes in solid state power amp eduard Power Supplies 12 7th October 2016 07:26 PM
Screen current through cathode resistors bigwill Tubes / Valves 20 28th July 2011 05:57 AM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 06:26 PM
Copyright ©1999-2017 diyAudio
