Peters Mighty Midget tube amp - diyAudio
Old 15th April 2017, 09:31 PM   #1
hifisucks's Avatar
Default Peters Mighty Midget tube amp
Hi, I ordered the board (from Peter Millet), the components for the board and Edcors PM-102.
Managed to build a quick set up to see what I bought and hear what I built... :-)
I have alot of hum in da speakers...
When I power up it is there and a lower hum mixes in 3 seconds later...
Where should I start to eliminate da hum?
Old 16th April 2017, 04:16 PM   #2
Ripcord is offline Ripcord  United States
Ripcord's Avatar
Hello Hifi, I built the Mighty Midget a while ago and it's quite as a mouse. Your pictures aren't very big so it's hard to tell but here is a quote from Pete Millett, "Note in the last photo the wire that connects the case to ground. Turns out that this is important - without it the amp was noisy and tended to oscillate. So do ground the chassis!"
Here is the link: The Mighty Midget and a picture.
P.S. Just wanted to add that the amp sounds fantastic!!
Old 16th April 2017, 04:48 PM   #3
hifisucks's Avatar
Thanks for your reply... but I have no chassis... at the moment... :-)
It shouldn't hum even without a chassis... I am not living next to a power plant... :-)
Old 17th April 2017, 12:50 PM   #4
wfmali is offline wfmali  Europe
Your pictures do not help much, too small - Pete Millet's board should be out of the question, they are usually very well though through. I would doublecheck part population and grounding and feedback. Relax, have a beer, say "omm" - you'll find the issue :-)
Old 17th April 2017, 02:46 PM   #5
hifisucks's Avatar
Between all the ommmmmmm sessions I had time to check all parts... all ok...
grounding what? The board has fixed all groundings... I guess... AND, I do not have a chassis to ground...
What feedback?
Boy, I am shortly before giving up...
Definitly, this will be my last adventure with tubes...
Old 17th April 2017, 05:02 PM   #6
TheGimp is offline TheGimp  United States
TheGimp's Avatar
One thing I notice in the schematic is the connection from the power receptacle ground to the ground lift diode bridge.
I can not tell from your pictures if you have this connection. Without it you will most likely get hum.
If there are no dogs in Heaven, I don't want to go there.
Old 17th April 2017, 05:05 PM   #7
TheGimp's Avatar
circled in green.
Is this internal to J3?
Old 17th April 2017, 05:58 PM   #8
hifisucks's Avatar
On the board it has internal contact... I also tried without D1... hums with or without......
Old 17th April 2017, 06:39 PM   #9
Bone is offline Bone  United Kingdom
You must have a metal chassis! Preferably put it in a metal box. Tubes are high impedance and will pick lots of ambient crap.
Old 17th April 2017, 06:48 PM   #10
Hums without audio source connected (input open) ?
Mighty Midget tube amplifier kit sale Fivetide Swap Meet 7 12th August 2014 05:44 PM
Mighty Midget Problem (One channel is louder) paristhecure Tubes / Valves 6 31st August 2013 10:49 PM
Mighty Midget Problems mike567 Tubes / Valves 12 19th November 2012 08:44 PM
Mighty Midget Amplifier and speaker requirements. Fivetide Tubes / Valves 2 28th October 2012 10:43 AM
My Mighty Midget tom42107 Tubes / Valves 6 17th October 2012 03:09 AM
Copyright ©1999-2017 diyAudio
