Anyone use ICs as input phase splitters for tube equipment
Old 19th March 2004, 10:18 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Question Anyone use ICs as input phase splitters for tube equipment
Tending towards the jensen transformers for this duty but before i make the plunge, i was curious about SS alternatives and their effect (or not) on the performance / sound in tube push pull circuits
this is at the input, so voltage swing at the output is not necesarily a big factor
thanks,
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 19th March 2004, 11:03 PM   #2
tubetvr is online now tubetvr
I imagine that it would not be so easy to use an IC as phase splitter as the grid voltage swing needed by most output tubes is quite high and most opamp IC's can only handle +/- 18V. it would be possible to make a discrete input stage with transistors without any problem but I cant really understand why someone want to do that.
I have never heard a hybrid amplifier of any kind that sounded as good as a good all tube amp so I personally stay away from hybrids. I am quite sure that I know some of the reasons why hybrids sound doesn't sound as good but it would take too long time to explain that here.
Regards Hans
Old 19th March 2004, 11:13 PM   #3
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default Re: Anyone use ICs as input phase splitters for tube equipment
Assuming you mean in front of a balanced tube stage, if your source is CD, you are just adding 1 more chip after the chips in the DAC before it hits the tubes, so how bad can it be? And, people have posted here that the DRV134 gives good sound even in front of discrete amps.
But I'm not a tubie at the moment, so I can't speak from experience.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 19th March 2004, 11:32 PM   #4
zobsky's Avatar
Regards Hans
No, .. I was raising the possibility of using the opamp as a phase splitter at the INPUT, ... before either the driver or the power stages , ..just looking for opinions
Old 20th March 2004, 12:44 AM   #5
OK, I understand and it has been done that way but I personally believe it doesn't have any advantages over a all tube solution IMHO.
I dont know if I should touch this subject or not as I am bound to get a lot of feedback of opposite opinions but I dont believe in interstage transformers either, I prefer to use tube based phase splitters, most preferably the split load type that I have found to be the best in most cases.
Regards Hans
Old 20th March 2004, 01:02 AM   #6
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default It just so happens...
I've just fired up a hybrid power amplifier with a JFET in the input stage. To my ears, it has a slight semiconductor sheen, but it's not bad at all. I have to say, though, that the (measured) distortion would have been lower if I could have used a valve at the input stage.
However, I think your question is more fundamental. A transformer can do a great deal more than simply phase splitting. It can also break earth loops and reject common-mode noise. You need a really good reason to mix semiconductors with valves.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Anyone use ICs as input phase splitters for tube equipmentHide this!Advertise here!
Old Tube Equipment Turnon Victoria Tubes / Valves 40 5th March 2006 01:18 AM
Phase Splitters teodorom Tubes / Valves 21 5th July 2005 11:10 AM
Using microphone transformers as phase splitters . Shoog Tubes / Valves 8 21st December 2004 06:30 PM
Phase splitters: Constant current sources BlackUnikorn Tubes / Valves 10 25th November 2003 03:44 AM
Copyright ©1999-2017 diyAudio
