211 Preamp
211 Preamp
Old 20th March 2004, 07:59 AM   #11
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
Originally posted by hacknet
would you attribute the organic sound to the 300b or the choke load?
Probably a combination....
cheers
- Jan -
Old 20th March 2004, 03:46 PM   #12
hacknet is offline hacknet  Singapore
hmm.. i`ll put that top of my list to get a pair of chokes...
analog_sa: wow, you know martin okay... i actually have a custom trafo winder in mind.
whats to keep in mind when picking a choke other than current capabilities? any special cores to look out for?
BTW, how do you determind the required inductance?
is it through the reactance of a choke to ac at the lowest freqency i want to achieve?
Old 20th March 2004, 03:59 PM   #13
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
211 Preamp
Exactly. So this reactance may be sufficient for a low Rp tube but not for a high Rp.
Nickel content is always good. Not so essential as for interstage transformer but still desirable. Your winder presumably has experience with plate choke winding geometry and knows how to achieve low parasitic capacitance. I mostly use two Lundahl chokes - 1667 and 1668 and between them they cover a large variety of possible tubes. A good friend of mine compared my Lundahls to his Bartollucis and couldn't qiote decide which was better.
Old 21st March 2004, 02:16 AM   #14
hmm.. okay.. thanks..
any one put a choke at the cathode and used it in a cathode follower?
211 PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
