diyAudio Sponsor
Old 17th March 2004, 07:57 PM   #1
Brap is offline Brap  United States
Default BLue hue
Probably nothing to worry about, but after about an hour or so, I 'm getting a slight blue hue from my 2A3 tubes on one channel alone of a 2 channel amp. I thinking it's slight manufacturing debris in the tubes?
thanks
Old 17th March 2004, 08:06 PM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
On the glass, or in the elements?
Old 17th March 2004, 08:09 PM   #3
It's on the glass portion, near the "shoulder" if that 's the correct terminology
Old 17th March 2004, 09:48 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Perfectly fine. I even have a 6SN7 that does it.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 18th March 2004, 12:09 AM   #5
Sounds perfectly normal Enjoy
Old 18th March 2004, 12:38 AM   #6
diyAudio Senior Member
fdegrove's Avatar
Maybe someone should explain, once again, where the blue hue comes from and how it will affect the useful life of a tube?
Don't ask, it won't be me doing the 'splaining again.
Frank
Old 18th March 2004, 02:28 AM   #7
Sch3mat1c's Avatar
Yeah yeah, blue glow on glass is perfectly fine, blue/purple/white glow from inside the structure might not be. I have some Russian 6L6s (erm.. 6pi3C-E or whatever) where the plate coating fluoresces light blue where the electron beam strikes it. I can barely see (due to visual obstructions and low current) the same in Hept'AU7's 12AU7s too. The real thing that you should worry about is a discharge between the cathode and plate, not a generic glow from inside.
Tim
Old 18th March 2004, 02:41 AM   #8
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Yeah, this is pretty simple. There are often just impurities in the glass or elsewhere in the tube that are easy to ionize and also emit light when this occurs. If the color shows right on the glass and not just floating inside the tube, then I see no problem.
I, like others here, have had tubes with a light glow on the glass or plates. They usually give me plenty of fine operation just like a tube that doesn't glow unusually.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 20th March 2004, 05:25 AM   #9
Majestic's Avatar
I've got one set of Philips/Siemens EL34's that do this.
I've never observed any sonic difference or penalty from having a blow glow from a set of tubes, but I've got to say thay look damn fine when listening to music in a darkened room!
check out my avitar and go easy on me ok? :-)
what the blue box rottbull Multi-Way 1 19th July 2007 03:33 PM
Big Blue Saw Rob M Everything Else 1 26th January 2007 08:00 PM
blue blue blue Duck-Twacy Pass Labs 2 2nd February 2004 01:27 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Page generated in 0.11429 seconds (76.76% PHP - 23.24% MySQL) with 11 queries
