I am trying to find a 360 Ohm / 50W non inductive resistor for thisKT88 SE amp
Wich one would you choose from this list? (Vishai Components) I think that maybe the RTO50 type would be ok, but there is also the RCH and RTOP that maybe could be fine. What brand of resistors do you use for this purpose? Cheers |
#2 | |
diyAudio Senior Member
I think to Sfernice should be available in Spain and it wouldn't surpise me if they're part of the Vishay group of companis as well since Vishays' been gobbling up quite a lot of companies the past ten years. The ones shown in the Vishay datasheet are thick film types, I never tried those but I hear WW is to be preferred. Cheers,
Frank |
#3 | |
Why non-inductive , I would have thought a 50watt aluminium clad wirewound bolted to the chassis do the trick ? I believe the 'non inductive' metal film power resistors can be noisy but will inductance be an issue with a 360 ohm resistor ? 316a |
#4 | |
In his designs Jean Hiraga always recommends the use of non-inductive WWs. Noise shouldn't be a big issue here as a NI WW should have no more than twice the noise of a regular WW resistor; 360 Ohm or 720 Ohm... Cheers,
Frank |
#5 | |
316a |
#6 |
It only needs to be 5W
#7 | |
Does WW means WireWound? In that case they maybe inductive. Isn't it? Sorry, my link to the Vishay was not the intended one. This is the correct one: http://www.vishay.com/resistors-disc...ive/res10-10K/ |
#8 | |
Brian. |
#9 | |||
That NI types are usually more than twice as expensive as the regular ones. The way they arrive at cancelling out inductance is by coiling the ni-chrome wire twice, once going the other coming. This is known as the Ayrton-Perry technique after its inventor. Quote:
Frank |
#10 |
i`d prefer to use a couple of 2 watt carbon resistors in parallel. this way, you got no induction and you should be able to dissipate enough.
try maby 4 in parallel to be safe. value should be about 1.5k 2watts. |
| SE 6V6 cathode resistor value | bereanbill | Tubes / Valves | 7 | 24th May 2009 04:11 PM |
| What is the RIGHT way to calculate the Value of the cathode resistor? | sgerus | Tubes / Valves | 22 | 18th December 2008 08:04 PM |
| TVA-1 cathode resistor value | audiohead | Tubes / Valves | 3 | 9th December 2007 07:15 PM |
| Choosing A Cathode bypass capacitor | alexmoose | Tubes / Valves | 11 | 7th April 2007 09:14 AM |
| Common Cathode Resistor | D0Hbert | Tubes / Valves | 1 | 4th March 2005 11:42 AM |
