Choosing a suitable 50W cathode resistor
Old 19th March 2004, 02:04 AM   #11
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Originally posted by fdegrove
That plus the fact that you need to consider fault conditions as well.
1. Resistors are rated for typical conditions at a typical temperature (usually 25ÝC). A heatsinked type may be rated for case at 25ÝC (like a transistor) whereas a sand resistor may be rated for ambient instead.
2. 5W is about 70% of the actual load. On a *really* hot day (or a typical one in India, hehe) in a stuffy chassis, it might have trouble.
3. Ah, I see you believe in burning a $30 tube to save a $.10 resistor...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 19th March 2004, 05:19 AM   #12
pingfloid is offline pingfloid  Thailand
pingfloid's Avatar
Going back to the catalogue, I guess that the correct one may be this one:
RW 19X64 NI AN 360 5%
http://www.vishay.com/docs/50016/rw.pdf
Now I just have to find a delaer (it is not the one they use to have in stock at the corner's e-shop)
Cheers
Old 19th March 2004, 06:15 AM   #13
hacknet is offline hacknet  Singapore
yup. thats the normal problem. and unless you are ready to order a 1000pcs of a single value, i don`t think you will be able to get any of these quality resistors.
Old 21st March 2004, 04:16 PM   #14
pingfloid's Avatar
Lightbulb Salomonic solution
While I try to find that resistor, I have decided to parallel 25 resistors 9k1, 5W each.
Old 23rd March 2004, 06:06 PM   #15
pingfloid's Avatar
I have found a dealer for the Vishai resistor. The price is 275 Euro each !!! and the delivery time about 5 or 6 weeks. He he he he...
I believe that my tandem of resistors will do a very nice job.
Choosing a suitable 50W cathode resistorHide this!Advertise here!
Choosing A Cathode bypass capacitor alexmoose Tubes / Valves 19 7th September 2014 11:08 PM
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 04:11 PM
What is the RIGHT way to calculate the Value of the cathode resistor? sgerus Tubes / Valves 22 18th December 2008 08:04 PM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 07:15 PM
Common Cathode Resistor D0Hbert Tubes / Valves 1 4th March 2005 11:42 AM
