6SN7 push pull flea amplifier project
Old 1st July 2018, 02:10 AM   #221
rongon is offline rongon  United States
rongon's Avatar
Originally Posted by kodabmx View Post
I usually use LM317 or TL783. Wouldn't those work in an LTP?
Yes, they work, and they certainly are easy to install.
Walt Jung's AudioXpress articles describe the use of constant current sources/sinks. Part 1 describes the basics of operation:
http://waltjung.org/PDFs/Sources_101_P1.pdf
Part 2 compares LM317 constant current source/sink with a DN2540 based constant current source/sink, complete with measurements, etc.
http://waltjung.org/PDFs/Sources_101_P2.pdf
The LM317 CCS is okay, within its limits. It gets inductive as frequency goes up; its impedance goes down above 10kHz. That means an LTP with an LM317 (TL783) in its tail will have balance that gets worse above 10kHz, introducing harmonic distortion on higher frequencies. Perhaps bypassing it with a film cap helps?
The single DN2540 CCS works well and has more constant impedance with frequency.
Later updates in AudioXpress compared the cascode DN2540-LM317 against the cascode made with two DN2540s. The version with the two DN2540s performs better. That's the preferred high voltage CCS these days.
Old 1st July 2018, 03:42 AM   #222
Carlp is online now Carlp  United States
Yes, and I've used them (DN2540) in the tail of an LTP front end. But the output stage baffles me...
Old 1st July 2018, 01:39 PM   #223
kodabmx is offline kodabmx  Canada
When it's bypassed by a giant cap I think of it as basically a programmable "smart" resistor.
Old 1st July 2018, 01:43 PM   #224
Great info. I remember reading these articles when I was younger If only they made a DN2540 with a built in Vref like LM317 so you didn't need basically a trimpot to adjust current.
6SN7 push pull flea amplifier projectHide this!Advertise here!
Chinese amp: 2A3 6SN7 6SJ7 5Z5P push pull Alexontherocks Tubes / Valves 16 7th May 2013 04:37 AM
6SN7 & 6V6 Push Pull - increase gain laosei Tubes / Valves 18 26th February 2013 08:01 AM
6sn7 driving Push Pull Parallel kt88's? ruben alstad Tubes / Valves 58 21st November 2012 11:08 PM
VTV Push-Pull 6SN7/KT88 Amp: DIY or China? 88man Tubes / Valves 5 18th October 2009 02:27 PM
YAPPAP (Yet Another Push-Pull Amplifier Project) arnoldc Tubes / Valves 16 6th July 2006 02:51 AM
