Actually, running the numbers over the datasheets the 6BQ5 doesn't do too bad as a lone regulator in this circuit. The circuit has -6V bias to maintain 30mA through the tube at 250v. If the 25mA load is removed the tube reaches equilibrium at 255v and -5V bias to pass 55mA. Not a perfect DC regulation but it keeps the output from shooting up to 350V if the load comes off.
Not sure if you've seen this yet but it is a shunt regulator that runs off a single pentode using it in pentode mode. Gets you more gain so you don't 'need' an error amplifier. Tube Based Voltage Regulators - Part 2STEVE BENCH site mirror by JACMUSIC
I think that's actually a series regulator with the VRs as error control. Voltage is dropped directly across the tube rather than the tube controlling voltage dropped across a load. Look where Bench takes the output.
He also has shunts on this page:
Tube Based Voltage Regulators - Part 5STEVE BENCH site mirror by JACMUSIC
edit: Woah, he has a 12AX7 cathode coupled amp on this page, too. How did I miss this?
- Tubes / Valves
- Can we talk about tube shunt regulators?
