DIY Single Ended Triode Designs
Old 18th March 2004, 08:46 PM   #11
Peter Menting is offline Peter Menting  United States
Saurav; would you share the schematic for the ECC99/ 2A3 setup? Would appreciate it.
Pete
Old 18th March 2004, 09:05 PM   #12
Saurav is offline Saurav
Sorry, I don't have a schematic handy, or any way to easily draw one. Here's a description, starting from the top (B+) to the bottom (ground), if that helps.
B+: 300 - 320V
CCS load set for 20mA, I used a Bottlehead C4S
ECC99 (plate), capacitor coupled to the 2A3 grid
Under the ECC99 cathode I've had the required resistor (bypassed) to get 4V at the grid with 20mA current. I replaced that with a NiMH battery, and that's what I'm using now. The +ve of the battery goes to the cathode, -ve goes to ground. I got my batteries from Radio Shack (cordless phone rechargables, 3.6V nominal, 4.1V fully charged), make sure their AH rating is high enough to be able to handle the steady state DC current through them.
Hope that helps.
Old 18th March 2004, 09:07 PM   #13
grataku is offline grataku  United States
Originally posted by AKSA
Has anyone here ever done a 6C33C in SET?
Any comments on operating point/sonics?
Hugh
Are you referring to something like the Erno Borbley 15W SE amp? I have been curious about that.
Old 18th March 2004, 10:10 PM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
B+ 200VDC
Vg- 80VDC
Zprim ~ 600 Ohm
Should sound great, needs grunty driver to overcome Miller capacitance.
SOME SOURCES OF INSPIRATION.
Frank
Old 18th March 2004, 10:41 PM   #15
AKSA is offline AKSA  Australia
Hi Frank,
Thanks a lot...
They seem to rave about them in Stereophile. Is this good or bad?
I was thinking of a 6BX7 driver, with rp around 1K3. I've ordered some at $US8 each.
B+, recommended by Alex Adrianov in Kiev, is 320V, 200mA, 85V of cathode bias. This is 235V across the tube, and 47W of dissipation, with max at 60W, so running at 78%, should last well, particularly if socket is raised for ventilation. They say a bit of pencil graphite rubbed on the pins prevents the filament current starvation which is the bane of these tubes.
I was thinking of a 1K:8R transformer to reduce H2/3 to the minimum. With increased voltage at B+ I should still get a good 10W.
First stage is 6SN7.
Comments?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 18th March 2004, 10:53 PM   #16
fdegrove's Avatar
Depends on what side of the fence you're sitting, I suppose.
A fellow member, 316A I think, once offered the following tip to prevent carbonised heater pins: when wiring up the heater connection at the socket, just wrap the wire around it a few times than solder it. This should provide for some extra metal surface to help pass current and keep things a tad cooler.
If it were for my own use, I'd find myself some NOS Johnson septar sockets. They're the most reliable I've ever used.
Hadn't heard the graphite trick before...I wonder how that actually works.
Comments?
Sounds fine by me.
Frank
Old 20th March 2004, 08:37 AM   #17
Graphite is greasy and conducting plus it has an inverse temperature coefficient (becomes more conducting as it's heated).
Could that help reduce the hot spots, hi resistance spots on the socket/pin interface??
I'll try that on my 300W halogen lamp contacts.
Old 20th March 2004, 11:28 AM   #18
morfeas is offline morfeas  Greece
As for the sonics of the 6C33 I would say a good mix between SS, SET. Still missing the energy of my PP 6550.
Runs on 235V, 200mA. Long time to burn in. The first 100 hours the bias comes after 30-40 minutes! After the burn in period 15 minutes are OK. Driver 6N1P.
A lot of HEAT that should be taken in to account seriously!
Old 20th March 2004, 02:19 PM   #19
wiligruen is offline wiligruen
Default 6C33B
one more source for inspiration.
Old 20th March 2004, 02:20 PM   #20
Attachment does not show up, will try later again.
DIY Single Ended Triode DesignsHide this!Advertise here!
Power cord for single ended triode kimobuddy Tubes / Valves 1 11th April 2009 06:47 PM
Running Single Ended 6V6 in Triode Mode WRyan Tubes / Valves 19 10th February 2009 05:09 PM
Best Cheap Speaker for Single Ended Triode Patrick Bateman Multi-Way 16 22nd December 2006 09:17 PM
single-ended bipolar designs? el`Ol Solid State 1 13th May 2005 07:22 PM
Single Ended Triode (SET) amp friendly design GaryF Multi-Way 5 30th May 2004 04:30 AM
