#31 | |||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
BTW, my friend still owns them but no longer uses them, he prefers 2A3 & 300B transformer and inductive/direct coupled Amplifiers he build from my designs. Quote:
I will admit that I rather like the idea of an OTL Amp, except I wish they could sound more to my taste than these I heard did. I have been thinking 6S33 SRPP with a Ongaku style driver and classic output coupling cap. In the end all the "OCL" OTL Amp's merely replace the coupling Cap with a pair of PSU Cap's and usually not very good ones. If I have to deal only with around 200V DC and a dozend volt AC I can make up a 2000uF Poly Cap in about the same size case as a nice OPT might fit in.... It'd probably cost more than a decent SE OPT too. Or maybe an inverted Futterman based around the Ongaku frontend? A little NFB in either case, just enough to lower the Z-Out to a level comparable to my DHT SE & PP Amp's, this could be attached to the middle stage, rather than to the input stage and add to that another loop from the middle stage anode to the input stage cathode, rather than one "long" NFB loop.... Sayonara |
#32 | |
diyAudio Senior Member
Either way, what's important is the endresult and I never had the impression I was listening to 2 pairs of 4000µF electrolytics....Let's not forget either that this is a PP amp. Since Nicos was asking me somewhat the same I did a little write up on life with OTL amps here: CROFT SERIES II OTL. Maybe I shoul also put that sticker up my bumper stating: "My other amp is a 2A3 PP" Which just so happens to be the absolute truth... Cheers,
Frank |
#33 | ||
Konnichiwa,
Sayonara |
#34 | |
I also used other speakers at when comparing amplifiers including some larger Audiovector model, (that I borrowed from a friend) and Quad ESL63. Regardless of speaker, I can quite easily here details in some recordings using my OTL amp that is masked by the SE amps I have compared to, I have also been running around in the high end shops in Akihabara and elsewhere here in Tokyo and been listening to many SE amps with different speakers, by using the same CD's I am used to listening to at home I have come to the same result, i.e that SE amps hide details in some music. I am quite surprised about the result myself as many people rave about SE amps but probably that is becaused SE amps make almost all recordings sound good, with an OTL amp you get to hear everything including bad recordings. Regards Hans |
#35 | |
After all, DC has to be stopped somewhere and with most OTL/OCLs I know of it's the opposing +/- rails that allow the extraction of the AC signal without DC riding along with it. BTW, I may have said this before, a very close friend of mine owns a set of AN Baransus and Lowthers. They sound fine even though I hear them humming on quiet passages but I'd never dream of using them in my system as they really don't offer anything the OTL can't do better. This, regardless of cost which let's face it, skirts the absolutely ridiculous. Cheers,
Frank |
#36 | ||
I sure have a hard time with that one... Quote:
Frank |
| Power cord for single ended triode | kimobuddy | Tubes / Valves | 1 | 11th April 2009 06:47 PM |
| Running Single Ended 6V6 in Triode Mode | WRyan | Tubes / Valves | 19 | 10th February 2009 05:09 PM |
| Best Cheap Speaker for Single Ended Triode | Patrick Bateman | Multi-Way | 16 | 22nd December 2006 09:17 PM |
| single-ended bipolar designs? | el`Ol | Solid State | 1 | 13th May 2005 07:22 PM |
| Single Ended Triode (SET) amp friendly design | GaryF | Multi-Way | 5 | 30th May 2004 04:30 AM |
