I recently finished up a tube line stage preamp aikido design. The existing pair outputs are hooked up to 2 heathkit w5 monoblocks which I have completely restored. Here is my challenge. I would like to add to the existing pair of outputs a second pair of outputs to drive a separate amplifier(stereo) to supply speakers in different rooms of the house. Do I add the jacks in parallel? Do I need load resistors? Any ideas, drawings,etc,etc,etc. I am also unfamiliar with balanced and unbalanced outputs nomenclature. Please clarify. Thanks again.
Cags
Cags
Yes. For your situation.
It gets complicated when the loads are heavier than a W5, or the source is lamer than John's stages, or you have a lot of loads to drive, or the show must go on even if some loads are shorted. But one "Aikido" can drive more W5s than you can carry home.
I will run a 2nd pair parallel to existing pair.
You can use a pair of Y connectors to try it out first.
