Compare the valve?
Administrator
Joined 2004
Not sure what exactly you are looking for? Valves popular with audiophiles or something else. Not aware of anything definitive or close to it.
There's this, I'd take it with a grain of salt: https://en.wikipedia.org/wiki/List_of_vacuum_tubes
There are lots of places with lists of interesting valves not well known to the non diy crowd.
Here is one of our member's sites: Bartola Valves – All about electronic valves and hi-fi
A very useful russian site: Tube List (English)
and
http://www.klausmobile.narod.ru/indexe.htm
http://klausmobile.narod.ru/td/list_e.htm
To the OP - it's more about getting linear response from a given tube stage. In my opinion, simpler tube designs (with fewer internal components) tend to sound better even though they may not measure as well as more complicated tubes.
The selection of tubes may be less important than building each stage for best response.
That typically involves heavy transformers. Mating these together approaches art: it's not a simple recipe.
I would advise beginning vacuum tube buy tubes that are still available.
I have an amp that I love which uses output tubes I can't replace.
Sent from my Nexus 6 using Tapatalk
