50W monoblock "Engineers Amp"
Old 21st May 2018, 07:49 PM   #161
anatech is offline anatech  Canada
anatech's Avatar
Good luck!
"Just because you can, doesn't mean you should" my Wife
Old 22nd May 2018, 04:29 AM   #162
kweaver is offline kweaver
Did any of you guys have trouble with a 60hz hum? I didn't notice it at first but now that I have, it is annoying to say the least.
Actually the more I dig into this, I think it may be a grounding issue. I rewired my rca inputs and grounded the shield on one end. It had no effect. Its just odd that both units are doing the exact same thing. Almost feels like it power related. Definitely more pronounced when running through my preamp than if I plug directly into the amps with my iphone.
Old 22nd May 2018, 03:35 PM   #163
kstylianos is offline kstylianos  United States
Just to follow up on my issue with rising bias currents.
I also swapped out R13 and R14 for 47k
I did this as well from the direction of Pete and bias levels leveled off nicely. Pretty darn steady now and seem to have settled in.
Old 25th May 2018, 02:19 AM   #164
So I am a bit frustrated with this hum issue. I have rewired my inputs exactly the way Pete suggested, using unbalanced guitar cable using the shield as ground. I tried lifting the ground on the on the power supply with no impact. They are totally silent when I plug directly into the amps from my laptop or iphone using a stereo to rca cable but as soon as I connect an actual preamp (and I have tried 3 separate units with different tubes) I pick up a bad hum. I have confirmed that the chassis are properly grounded
Old 25th May 2018, 03:06 AM   #165
Are IEC and PCB board grounds connected to chassis, preferably as same location? Sounds like something upstream from amp. Is hum induced, using same chain of components, with another amplifier?
Old 25th May 2018, 04:19 AM   #166
So embarrassing as this is to admit. You were entirely correct. It seems it was nothing more than a bad cable. Not sorry that rewired the inputs though as that did seem to help quiet things down even more. We are running perfectly quite now.
As for the heat; I removed the bottom panel and installed feet to get the units off the surface. Running much cooler now. I couldn't be happier. These things sound incredible.
BTW I never realized how much noise a phone could create just by proximity to preamp tubes, even when not physically connected.
Old 15th June 2018, 07:50 PM   #167
pmillett is offline pmillett  United States
pmillett's Avatar
Default New version of PCB without sockets
Hi All -
I now have a version of this board with no tube sockets... just holes so you can chassis mount sockets and wire them up however you want. So you can use whatever tube!
Pete
Old 15th June 2018, 09:43 PM   #168
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Nice!
21/6HJ5, 21LG6A, 21/6EX6, 6CB5A, 26DQ5, 22/17KV6, 33/21JV6, 21HB5A, 22/6KM6, 35LR6, 13/6GB5, EL500, EL36, EL86, 10/6JA5, 21KQ6, 6P36S, 6P44S, 6P42S, 6P45S, 42KN6, 40KG6, 36LW6....
Old 22nd June 2018, 03:47 PM   #169
cbueche is offline cbueche  Switzerland
Thanks Pete for again delivering such a beauty ! Eagerly awaiting where George will push this nice one
50W monoblock "Engineers Amp"Hide this!Advertise here!
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
PICS: "Optimos" 140W Monoblock Amps! Rarkov Solid State 50 28th April 2011 01:54 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
