What are you trying to build, a matched gain 2 channel preamp?
What signal source will you use, phono cartridge, CD player, etc.?
(How much input signal voltage do you have?)
How much output voltage do you need?
The above schematic is a mystery to me.
Also, a reference to Scott's G=1000 amplifier does not include a link to it.
http://www.diyaudio.com/forums/grou...1000-low-noise-measurement-amp-ikoflexer.html
The control loop idea is brilliant but won't work without major redesign, for triode.
why not?
at least for this tube it looks like O 100 nA grid leakage at typical ~-1 Vbias given the graphs with 10 Meg grid leak bias
so the "opto diff amp" servo Scott shows would have enough "authority" if you wanted ~ 1 mA in the tube, would then have ~ 1 uA in the opto PV
Jcx , you cannot get the sound of tubes without tubes, I am a SS guy first and foremost.
I designed a 3 transistor 3 tube amplifier that can't be beat by Silicon alone.
I gave up and and now have 6922 tubes in my equipment. I won't be going back to SS alone.
The band sounds like it's in the room. By the way a 6922 tube can be had for less then $10
- Tubes / Valves
- Opto to bias triode?
