Stromberg ASR-880 Biasing
Old 18th January 2017, 02:09 AM   #21
Lawrk is offline Lawrk
Re-reading the entire thread, I like your earlier idea about putting the power resistor in the power supply primary. That sounds like a much better idea than what I said about putting it in the secondary.
As a test I can reduce the line voltage to 117 Volts with a Variac and see what I measure on the DC side.
Old 18th January 2017, 02:46 AM   #22
PRR is offline PRR  United States
PRR's Avatar
> R91 and its Br,R,Gr 1.2M Ohm.
Ah, me wrong, too much squinting. There is a Balance pot and two 150K hung on that. So the string is more like 10K, 5K, 70K, and some others. Given 60V in, about 45V at the grids.
My point remains. If you want the tubes to idle hotter, reduce the to-ground resistor. Try a 1Meg or 500K across the 1.2meg. Get to "a little too hot", then you can trim-back with the trimmer.
Stromberg ASR-880 BiasingHide this!Advertise here!
Stromberg Carlson ASR 220C blowing fuse jprisco Tubes / Valves 4 11th May 2013 09:09 PM
Stromberg Carlson ASR 433 lugnut Tubes / Valves 2 2nd October 2011 06:41 PM
Stromberg-Carlson ASR-433 Bran Kulez Tubes / Valves 10 20th October 2009 07:23 AM
Newbie wants to rebuild a Stromberg Carlson ASR-433 ficklecycler Tubes / Valves 11 16th April 2009 01:39 PM
Stromberg Carlson ASR 533 kc5scs Everything Else 0 22nd January 2008 02:58 AM
