6GT5 distortion problem
Old 14th March 2004, 03:08 AM   #1
imix500 is offline imix500  United States
imix500's Avatar
Default 6GT5 distortion problem
Hi, I have a precision electronics amp with 4 6GT5 outputs that has been dormant for a year. After plugging it in I find that I can only get low volume that's mostly distortion. It appears that the B+ rail is being taxed heavily as the 0A2 regulator dims when signal is applied. All caps were replaced 1 year ago. Any ideas? Thanks!
Old 16th March 2004, 02:52 AM   #2
imix500's Avatar
Also, the unit seems to be drawing several solids Amps from the AC line when input signal is applied. Could the output stage be saturating way early? Thanks!
Old 16th March 2004, 02:59 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Did you reform the caps when you put the unit back into service?
It sounds as if you have a considerable amount of leakage current somewhere along the PS which could be a dead cap.
Frank
Old 16th March 2004, 03:15 AM   #4
imix500's Avatar
Frank, when I recaped the amp nearly 2 years ago actually, I didn't know about cap reforming and just checked polarity and powered it back up when I was done. The amp worked well for about a year and it has sat in a closet for about a year. Could one of the caps died that quickly? Does reforming them increase thier life when put into service? Wouldn't a bad filter cap also come with some 60 cycle hum? Thanks!
Ricky
Old 16th March 2004, 03:23 AM   #5
fdegrove's Avatar
It's certainly not impossible. Electrolytics need reforming after a long period of inactivity.
60 Hz or actually 120Hz hum is one indicator of a faulty cap but since you're using a regulated supply I suspect it rejects quite alot of PS hum.
Mind you, I could well be wrong in my analysis of the problem.
It just seems a good place to start looking...
Frank
Old 16th March 2004, 05:58 AM   #6
imix500's Avatar
It's a good starting point to check the caps then, hadn't suspected them. Thanks Frank.
Old 19th April 2004, 06:20 AM   #7
imix500's Avatar
Ok, found the problem. There was a direct short to ground in the output connector, so the distortion was the transformer saturating and possibly the output tubes as well. It's the simple things like those that are frustrating. My question now is, could I have damaged the outputs by driving them into a dead short?- through a transformer of course. They never glowed red and niether transfromer got warm during testing. It sounds ok but I won't know for sure until I put it through it's paces. Hoping I just got lucky this time. Thanks,
Ricky
Old 19th April 2004, 06:28 AM   #8
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I doubt it. Not unless the anodes (plates) ran red for any length of time.
According to your description of the symptoms, the power supply sag limited dissapation.
6GT5 distortion problemHide this!Advertise here!
6GT5 audio amp? bereanbill Tubes / Valves 2 1st June 2009 12:37 AM
X-150 distortion problem jeffjazz Pass Labs 2 13th March 2009 09:16 PM
Precision Electronics Amp w/ 6GT5's, Convert to 6L6's? tablebeast Tubes / Valves 5 11th August 2005 08:57 PM
Odd distortion problem wintermute Solid State 16 10th October 2004 01:40 AM
Help! distortion problem Kilowatt Solid State 12 3rd January 2002 04:05 AM
Copyright ©1999-2017 diyAudio
