| diyAudio Sponsor | ||
#21 | |
diyAudio Senior Member
Frank |
#22 |
Tim, one nice thing about CF drive is that you're not necessarily limited to the idle current of the CF. On positive swings, if the tube is capable, the output current of the CF can be considerably higher. On negative swings, well, who cares?
FWIW, I've had no trouble driving 2A3s with a 6SN7-based CF, though my preference is still for a mosfet source follower in this application. To paraphrase a bright young fellow I know, the best device is the one which suits the circuit electrically.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#23 | |
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#24 | ||||||||
You obviously believe that since you don't understand the point the writer is wrong. Foolish thinking. Categoric statements are the security blanket of the inexperienced. Quote:
And what's the problem with cap coupling anyway? You can drive a loudspeaker surprisingly well via a cap, all the better if it's a good one. A cap coupled plate to output grid reduces the chance of biasing accidents as well, particularly if the output tube is cathode biased. A DC coupled tube circuit is nice in theory, but as the tube ages, operating points cascade down the line..... Your post is confrontational. Tone it down. Cheers, Hugh |
#25 | ||
High,
If only you'd see that big This topology isn't really all that unusual in the sense that it's quite accepted practice in Japan. Kondo, Sakuma amongst others have been doing this for many years. These designers, yourself included bien entendu, know what sounds good because they actually go out and listen to what they put to paper. It doesn't stop to amaze me how much time passes by before people put aside what they've been taught at school and actually start thinking for themselves. Sometimes travelling light, educationwise, isn't such a bad thing after all...Tabula rasa style... No offense to solid engineering, of course, it's just that when it comes to audio, things aren't always as cut and dried as they're thought to be. Quote:
Just imagine the worst of the worst, believe me I've seen it done, where two stages run from independent B+ supplies are direct coupled to each other... They still wonder why it works fine one minute and not so good the next... Not that it can't be done, technically spoken, provided you keep the lot at the same operating point, i.e. rock solid stable. Ah well, Rome wasn't built in one day either... Cheers,
Frank |
#26 | ||||||
The sound isn't much different between these two amps here, Frankenhouse and Hept'AU7, as compared to my quad 6L6 amp. The former pair sound better of course because they're in stereo. Interesting, especially since Frankenhouse is a PP pentode amp with global NFB while Hept'AU7 is a ZNFB PPP triode amp. (Quad 6L6 is PPP pentode with global NFB and at least 60W available so it has far more dynamic range.) Quote:
6BX7 plate follower, cap coupled - plate resistance = 1.3k did you say? 6SN7 direct-coupled cathode follower - Zo = less than 300 ohms, far less with additional NFB applied locally Now tell me, which one will go phut when subjected to a varying load? Which one will cause bias drift, and thus class AB2 operation when near full power? Quote:
Tim
| 20W cathode follower amplifier | yan24 | Tubes / Valves | 120 | 3rd January 2009 05:16 PM |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 07:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 03:12 PM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 09:49 PM |
| Page generated in 0.14118 seconds (83.99% PHP - 16.01% MySQL) with 11 queries |
